Harman Accentra Insert OAK
Justin M Posted By Justin M, Dec 5, 2012 at 2:54 PM
Thread Status:
  1. Justin M
    Justin M
    Feeling the Heat 2.
    NULL
    Dec 22, 2008
    283
    86
    Loc:
    Southbury, CT
    Where does a Harman OAK terminate for an Accentra insert with a masonry chimney? Does it only go part way up the flue and use a spacer on the block off plate, or go all the way up? And in either case what prevents it from sucking in combustion air from the exhaust?
  2. kinsmanstoves
    kinsmanstoves
    Minister of Fire 2.
    NULL
    Aug 29, 2007
    3,480
    501
    Loc:
    Ravenna, Ohio 44266
    drill through the back wall of the chimney and run it or run it up to the top but in a way it will not suck in exhaust. The liner on your Accentra better go all the way to the top of your chimney.
    Eric
  3. Justin M
    Justin M
    Feeling the Heat 2.
    NULL
    Dec 22, 2008
    283
    86
    Loc:
    Southbury, CT
    I forgot to mention that the chimney is in the garage so I can't do that. Yes, the liner goes to the top, that's why I was wondering about pulling intake air right next to it.
  4. kinsmanstoves
    kinsmanstoves
    Minister of Fire 2.
    NULL
    Aug 29, 2007
    3,480
    501
    Loc:
    Ravenna, Ohio 44266
    It has been done and Harman makes a special cap but I have never used it. I can not locate the part number right now but will keep looking.
    Eric
    Bridgeman likes this.
  5. Delta-T
    Delta-T
    Minister of Fire 2.
    NULL
    Feb 27, 2008
    3,144
    580
    Loc:
    NH
    #1-00-674104
    Adjustable Chimney Intake Extension....also have never used one, but thats what you'd be looking for
    Justin M and kinsmanstoves like this.
  6. Justin M
    Justin M
    Feeling the Heat 2.
    NULL
    Dec 22, 2008
    283
    86
    Loc:
    Southbury, CT
    Thanks, I'll look in to that at my dealer. Does anyone have any experience with that setup?
  7. holstein
    holstein
    Member 2.
    NULL
    Jun 27, 2010
    35
    3
    Loc:
    Goffstown, NH
    We have this setup on our Accentra insert. Works great. We also opted for the official Harman OAK kit which mounts the intake to the frame in the fireplace matching the exhaust. 3" intake pipe goes up the chimney a few feet beyond the damper block off.
  8. Justin M
    Justin M
    Feeling the Heat 2.
    NULL
    Dec 22, 2008
    283
    86
    Loc:
    Southbury, CT
    Good to know. What setup do you have at the top of the chimney? Is it just a spacer on the block off plate to allow air down the flue?
  9. holstein
    holstein
    Member 2.
    NULL
    Jun 27, 2010
    35
    3
    Loc:
    Goffstown, NH
    Yes, the extension kit is a four sided rectangle with louvered sides whick allow air intake. The extension is mounted to the crown of the chimneyvand the block off is then mounted to the top of the extension.
  10. Justin M
    Justin M
    Feeling the Heat 2.
    NULL
    Dec 22, 2008
    283
    86
    Loc:
    Southbury, CT
    How much does it raise the block off? Just wondering if I have enough slack in the liner.
  11. CtPaul
    CtPaul
    Burning Hunk 2.
    NULL
    Sep 16, 2011
    139
    40
    Loc:
    CT
    I have the Harman kit sitting in my living room waiting to be installed. I will take a couple of pics this weekend. I'm waiting on a block off plate from local tin knocker and a new top plate for the chimney. I plan to install the OAK next week. I'm glad to hear Holstein has had good results. My install is a little challenging because I have an old fieldstone fire place. So it is going to be fun getting the block off in place!
  12. mrjohneel
    mrjohneel
    Feeling the Heat 2.
    NULL
    Dec 8, 2011
    264
    39
    Loc:
    Suburban Boston
    My Harman insert in an internal fireplace has the exhaust liner going to the top through a top plate that has an open grid around the bottom to allow air in the chimney. I then terminate my OAK half way up the chimney well below the exhaust. It's been working well.
  13. deercamp
    deercamp
    Member 2.
    NULL
    Jan 3, 2013
    119
    11
    Loc:
    se mass
    Looking for some help here. What most of the post are saying on here is that they are only running the oak halfway up the chimney and it's working
    great for them. This is what I was planning on doing. I called Harman direct to ask them a few different questions and they told me with the new 52i insert that I should run the oak all the way up to the top with the exhaust pipe. They said if I did not that there would be a loud rumbling noise. So is there two separate places on the adjustable chimney intake extension # 1-00-674104 to attach the 4" exhaust and the 3" oak? If so is this the only cap I need on top of the chimney? Ty
Thread Status:
