DAKSY said:Well...Somebody else jumps on the bandwagon.
When they first came out they were supposed to be the best thing since sliced bread, but now...
Finicky, ridiculously finicky remotes...
Too much componentry crammed into too tight of a space in the valve cavity...
The fronts - at least some of the ones I've installed - are poorly designed...
The surrounds don't have an exit notch/hole for the blower lead cord.
The blowers are the open squirrel cage type with no shrouds...
No flame or blower adjustment UNLESS you have one of the finicky remotes...
What did I miss?
jtp10181 said:We have had some problems here and there.
Mostly its the IPI-Plus system, not anything with the design of the inserts.
Everything so far has been resolvable, although annoying.
If you have any specific questions or problems I could go into more detail.
It's not very professional to just start a groan session.
Wood Heat Stoves said:jtp
to be clear, i was in no way referring to hht products( i guess i missed something, are you hht employed?)
my nightmares with modulating valves/servos were from Lennox and Travis...
JC93 said:So in regards to the flame recifications issues what have you guys done to correct them? I have a Cosmo-I-30 that I have checked and tried everything and the flame recification is still not working. I have tried bending the rod closer, installing the "new" pilot assembly the factory says will fix the issues and it does not. Any suggestions?
