Wood Duck
You're not going to be able to dry out the whole split very much in an hour or two on the stovetop. I bet you can dry out the outer layer that is touching the stove, but not the inside. Cracks int he wood indicate that the outside is drying faster than the inside, which is exactly what you'd expect with the wood on a hot stove.
If you can stack the wood indoors for a week or two you can probably make a much bigger difference than an hour on the stove. A fan blowing on the wood is a great way to speed drying, even if the wood is in a cool basement or garage.
I would expect the wood to vary a lot in moisture content. Some rounds were probably in contact with moist soil, some maybe on a dryer spot. Even within a single round, the bottom is probably wetter than the top after two years in the same spot.
