It has to do with the melting points of some solder being lower than the temperature of some parts of the stove that the joint may find itself near. The insulation on the wiring is a high temperature insulation.
ETA: Solder has melting points ranging from 244 to 585.
Thanks for the assist there, Smokey.
People don't realize that soldering isn't welding. With igniters reaching well over 1000 deg it doesn't take long for heat to backtrack along the wires to the solder joint and bring it to the melting point. I have even seen active electronic components melt the solder off their leads when the soldered connection was not properly cooled during operation of the circuit. A good gas tight mechanical connection (crimp) will never have those problems.
Should you be able to feel the warm air coming out of the igniter hole.I have a friend who just picked up a refurb model.The igniter comes on as you can see a red glow in a hole right of the auger.But want light the pellets.It runs for 20 minutes and shuts of. they get lit manually.
You should be able to feel heat above the burn pot over the igniter hole, do not place anything in front of that igniter hole as it can get very hot there even if it doesn't light the pellets, it is a severe burn risk.
The area around the igniter may have some dirt in it or the igniter is improperly positioned in the stove. I'd suggest that your friend call England. In some cases (high altitude situations) there is an additional air hole that has to be opened to allow enough air to be heated to start a fire.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
