I bought my englander 30 from Home Depot. I have yet to gt it installed but it looks like a heating machine. and with all the reviews on here I am sure it is.
Yes, I'd say, for the most part. Getting heat from a woodstove to go downstairs is just an exercise in futility and frustration. Rick
If somebody is not producing good heat from an NC-13 then either the install is faulty or the operator is faulty. They are fine little stoves that I have several hours of sitting in the presence of.
Personally the super 27 sounds about like the right fit. You start talking Summit and you are talking about a pretty big stove (but hey, I LIKE big stoves). Your ability to move air will play a big factor in the comfort level of using a big stove.
All my woodstoves including the 30 get over 700 Deg stovetop while burning. This guy probably had green wood. No mention of Stove temp. First time wood stovers make that mistake often.You must have missed this review: https://www.hearth.com/talk/threads/nc-30-review-funny.88918/
What is it about this stove that makes burn times better? It seems like on any 2 cf (EPA) stove, you would just have to get the damper turned down far enough which means dirty burning on any non-cat. Does the PE allow less air on "low" or is it some other characteristic?The super 27 is one of the few 2.0 cuft stoves that will comfortably run that long on a wood load.
Incorrect. When burning right, the air controls are usually all the way closed, or very close to it, when running a non-cat. With the Heritage, I would have the air controls 'closed' and the pipe damper close while having the stove cruise at 550+ degrees with no smoke from the chimney.What is it about this stove that makes burn times better? It seems like on any 2 cf (EPA) stove, you would just have to get the damper turned down far enough which means dirty burning on any non-cat. Does the PE allow less air on "low" or is it some other characteristic?
Ok so I got my first esitmate today. I break it down for you:
1 metalbestos OR Duravent Chimney system $2,285 installed.
1 Pacific Energy Super 27 Heritage w/blower and ashpan and single wall black pipe connector $2,725 installed.
This doesnt include a cement board hearth
This also doesnt include the framing that will need to be done to the hole left by my metal fireplace.
Comments please.
I just had a dealer sales guy tell me that you aren't supposed to just lay a cement board down on the floor flat without an air space, and that premade hearth pads have that air space. I haven't heard that before and I want to do just that (cement board right on the floor, over the carpet if possible - simple as I can make it). Any truth to that air space thing?This stove only needs ember protection for the hearth. You could lay down some cement board and cover it with tile for under $100.
