    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. ivanhoe Member
    it seems i'm stuck at the choices for a placement of a fahrenheit furnace in the basement. it's my ideal furnace add-on and looks like i'm forced on the following exhaust piping scenerio. t-pipe to 6-7ft rise then elbow to about 8ft horizontal with some rise at every foot and then i'm outside and t-pipe to whatever vertical needed(6-7ft) to clear the filling and venting pipes of the oil tank at a safe distance. i was leaning on a selkirk DT piping. do i forget about such installation or go ahead knowing i will probably have to clean the pipes more frequently. finished basements can such headaches at times:mad:.
    #1
    Helpful Sponsor Ads!
  2. DexterDay Minister of Fire
    NE Ohio
    My best guess, would be that it's o.k..
    As long as its a newer unit, with the newer upgrades/mods, and you keep an eye on the horizontal.
    I have seen a Fahrenheit with the most unorthodox venting set-up and it runs fine. (Direct vent w/ 3" vent and a down turn (yes, down in the vert install. 90* down)
    But, my best advise is to call and speak with Matt Fitts or Mark Graham. Spoke with both and they are not only extremely knowledgable, but extremely helpful.
    I have 4 ft horizontal, after 5 ft vert, and I have burned 1.5 ton, and its hardly noticeable. So an extra 4 ft?? May be easily done?
    Which one are you lookin at??
  3. ivanhoe Member
    not sure yet, is there a difference of models or in this case, year built? i just want to make sure it's feasible before splurging on a furnace type of stove. i would put it where the accentra is but the raised hearthpad falls short. i would also like to keep the accentra for back-up in case of waiting for unforeseen parts requirement. giving matt or mark a call should be in the cards.
    thx,
