Husqvarna 450 Rancher Chain and Bar oiler can not be adjusted !!??
jimDlux
1
Piedmont SC
"Factory set oiler that is under performing." any help for an aftermarket fix??
I contacted a "Husqvarna Expert" (at the Huqvarna website) and got referred to a local dealer. ...maybe an aftermarket oil drive wheel gear? with a faster pitch?
So I called a local dealer and they knew about the problem but had no idea how to fix it. They tell me Josered is owned by Husqvarna but had no idea about changing out parts for a 450. any help?
If you get yourself a welders tip cleaner I bet the oil ports are clogged on your bar .clean out the ports and the groove in the bar. It will need to be done about every 3-4 gas fill ups.
Reactions: Investmentdude
