Is There an Insert With an Thermostat?
Malatu Posted By Malatu, Nov 22, 2012 at 9:32 PM
  1. daleeper
    daleeper
    Minister of Fire 2.
    NULL
    Dec 18, 2006
    553
    28
    Loc:
    NC MO
    Hey, great to hear your update, and hear that it is working well.
  2. mellow
    mellow
    Resident Stove Connoisseur 2.
    NULL
    Jan 19, 2008
    4,750
    654
    Loc:
    Salisbury, MD
    If I had kept my tube secondary stove I would be using smartstove right now. Easy to setup when you only have 1 control on a stove, now that I have a Cat stove that need for long burns has been fulfilled.
  3. dafattkidd
    dafattkidd
    Minister of Fire 2.
    NULL
    Dec 11, 2007
    1,733
    332
    Loc:
    Long Island
    Hey, can this product be installed on an Osburn 2400i? How complicated is the install? Thanks.
  4. ControlFreak
    ControlFreak
    Feeling the Heat 2.
    NULL
    Jan 15, 2008
    492
    9
    Loc:
    Holden, MA
    Hi Kidd,
    How difficult is it to put SmartStove on an Obsurn 2400i? That's a great question, but one that you'll have to answer yourself. I'm not going to retrofit this to your stove, you must do that part. So, the difficulty is as much dependent upon your skills and access to tools as it is to the specific stove.
    Questions you need to ask:
    1. How much friction is there in the existing draft control? How difficult would it be to eliminate that friction?
    2. Is the draft control port available, or is it permanently welded inside somewhere? (This is the case with the Hampton HI300). Access to this port can be important if you have to rework it to reduce friction. I solved that problem by some significant surgery, seen here: http://inveninc.com/SmartStoveForum/index.php?topic=19.0
    3. Is there a location where you can hide a couple small electronic modules and isolate them from heat?
    4. Is there a location where you can mount a small actuator and provide a linkage that ties it into the existing draft control?
    I will be adding two additional threads to the InvenInc.com forum, for the Napoleon 1402 and for the Englander 13NC. The Napoleon is one of the easiest, the Hampton was one of the most difficult.
    Happy New Year!
    Dan
