Issue with Harman Insert p52i - newer model
kennyp1960
1
Ct
So started having issue with start-up or reactivation on room temperature. Sometimes on startup or the stove does start up, the exhaust fan starts, the ignition light comes on and the auger start feeding pellets. Some time the auger stops, the ignitor light goes off and the exhaust fan stays on..... No error codes....
The other situation is the stove doesn't reactivate just nothing happens and the room is colder then the temperature setting.
I noticed I pinched the room temperature probe when inserting the insert after annual cleaning, small tear in the jacket of the wire but the inside wires appear fine...
I have had a couple of occasions where I thought the stove should have kicked on based on room temperature. I shut the stove off for a while and came back to it or switched to stove temp mode until it got going and switched back to temp mode. Once I unplugged the stove for a few minutes and that worked, too.
You may want to check the resistance of the room temp probe to confirm you didn't cut thru the wire. You can also try running it in stove temp/manual to see if it keeps running. Like Peterfield I've had to power cycle my stove to get it back to normal.
