Kiln dried kindling?
P
Pallet Pete
Guest
Anybody know where in Michigan I can buy a pallet of kiln dried kindling for wood stoves?
Thanks
Pete
I'm not in Michigan but I get mill ends for $20 a bin (1/3 cord). I would search for lumber mills and see if they will sell you ends or dunnage. I could buy carts of dunnage (way over a cord) for $40 when I worked at a mill. I burn the mill ends all day and save the good wood for the evenings.
Not sure about a palette load, but cabinetry shops and flooring shops are a good place to look for kiln dried scraps.
Or instead of buying a pallet OF kindling, you can use old pallets FOR kindling. Careful of the nails.
Buy pallets of kindlin? Pallettes is what I use for kindlin. Check craigslist in your area under free. I'll bet there are plenty to be had or just do some dumpster jumpin at a construction site.
Check if your local high school has a woodworking shop. Ours has a dumpster out back that is loaded with scrap that would make good kindling. You may need to pick through it for what would be appropriate to burn. Haven't checked out ours yet because we have plenty already but know of several others who use it as a regular source of kindling. Of course, my hubby doesn't like me to "find" more wood because I tend to have piles, trailer loads, etc etc of the stuff.. always thinking of ways to use it for projects and saying "I can make something out of that!!". ;)
Buy? The OPE store around the corner puts out these nice pallets, more than I can use, and there are ALL oak! Check around, you should be able to find free wood.
Why not just dry your own kin'lin. With the large ratio of mass to surface area, it doesn't take long. I split up one or two years worth at a time and store it in the house.
Kiln dry MC will vary depending on intended use. KD construction lumber is sopping wet compared to KD for furniture or cabinet making. How it is stored is also a big factor.
Here in Iowa (at least it was this way a year or 2 ago) you can have a small dump truck of scraps delivered to your door from a pole building company, they dont have to deal with the scraps that way, I guess some of the pieces are 4 feet long or better.
lligetfa I usually split it as I need it for cold starts from pine but I am looking to simplify. My work place told me the other day to take our old pallets and cut em up so I am gonna do that and see if they work.
Thanks wes999 for the Idea
Pete
Pete, I have some extra kindling on hand if you need it. Come on over next spring while I'm splitting and I'll show you a way to make kindling super fast!
I would love to do that Dennis Thank you I would love to know how to make it faster. I have kindling right now but I can say this stove will take a lot more compared to the old one so hopefully it lasts the winter. If I run out I would willingly pay you for it.
Thanks again
Pete
Just give me a call Pete. We have a pretty good amount as it appears the train people won't need any this year and I'll certainly make a bunch next spring. I'll save that until you can come over so you can see how fast and easy it is to make the Backwoods Savage way.
I get more kindling than I can ever use from deadfall branches from all the trees on our lot each year .... and we have only a half acre.
If you run out of that type of kindling jharkin, feel free to come scour our woods. We have plenty. Especially after cutting a few thousand pine trees we now have a super amount of pine that can be used for kindling.
