lopi Berkshire soot
peedenmark7 Posted By peedenmark7, Sep 2, 2013 at 4:46 PM
Thread Status:
  1. peedenmark7
    peedenmark7
    Member 2.
    NULL
    Oct 22, 2010
    66
    0
    Loc:
    wisconsin
    Hi guys..
    I've been running a Lopi Berkshire for the past 4 seasons and really like the stove.
    At the end of the '11 heating season I noticed some scant soot build up inside the stove and on the glass to a small degree. Cleaned it and ran it last season.
    Now as I clean and begin to ready for this winter I am again cleaning and noticed quite a bit of soot on the glass and on the floor and inner walls of the unit..
    What is the problem ?
  2. DAKSY
    DAKSY
    Patriot Guard Rider Moderator 2.
    NULL
    Staff Member
    Dec 2, 2008
    6,658
    1,202
    Loc:
    Averill Park, NY, on Burden Lake II...
    What fuel are you burning? If LP, find the air shutter & adjust it to wide open. See if that helps. If the flames are too blue for your liking, close the air shutter in 1/8" increments til they start to look orange, & then open it 1/8", lock the screw & leave it alone. You shouldn't have any issues in the future. If the air shutter adjustment doesn't work, report back...
  3. Heatsource
    Heatsource
    Minister of Fire 2.
    NULL
    Dec 19, 2011
    1,051
    156
    Loc:
    Northern CA
    Also, carefully inspect the burner- where the cast or stainless base is attached. sometimes the furnace cement or sealant has failed. this has been a point of failure in the past....
    DAKSY likes this.
  4. DAKSY
    DAKSY
    NULL
    Staff Member
    Dec 2, 2008
    6,658
    1,202
    Loc:
    That's EXACTLY why this forum works. I can cite usual corrective actions from a service standpoint, but never having worked on that model, like Dave obviously has, I can't cite specifics. No way for me to know about that burner thingie...One way or the other, someone in this forum has run across just about any problem that a customer with a hearth appliance has encountered...
    Heatsource likes this.
  5. Heatsource
    Heatsource
    Minister of Fire 2.
    NULL
    Dec 19, 2011
    1,051
    156
    Loc:
    Northern CA
    no experience with that model specifically but the "emberfire" burners from travis ind
  6. peedenmark7
    peedenmark7
    Member 2.
    NULL
    Oct 22, 2010
    66
    0
    Loc:
    wisconsin
    Hi guys.
    Thanks for all of the replies... Air shutter was about 2/3rds closed. Set it correctly and made a few other adjustments and she seems to be running fine, though its been real hot , so only a night and a half of burning the past 2 weeks after the adjustments.
    Odd though, as I have not changed a thing on the stove since its initial installation.
    I was made aware of the problem that Lopi had with the stainless burners flexing thus throwing off the mastik/white caulk crap on the bottom which mine has. My dealer put in a call to Travis and I got one for roughly half price, [ a year ago it would have been fully covered I was told]. Though with this being a well known issue thus the change to Cast Iron for the burner plate, one would think this should have been recalled / fully warranted.
    Love the stove, but will think twice on adding a Greenfield.
  7. Heatsource
    Heatsource
    Minister of Fire 2.
    NULL
    Dec 19, 2011
    1,051
    156
    Loc:
    Northern CA
    also might want to check the draft restrictor setting, maybe it is out of spec as well
Thread Status:
