    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. jankdc New Member
    There is no insulation value to this stove board. It doesn't say it on the packaging (which says that it is for wood stoves). In the instructions it states: R-value = 0. If you need a stove board, check out the type 2 stove boards from Hy-C. I've tried 3 times to post a negative review on the Lowes' site. They keep getting rejected. Hopefully this last one will go through.
    #1
    Helpful Sponsor Ads!
    raybonz likes this.
  2. Backwoods Savage Minister of Fire
    Michigan
    Thanks for posting that jankdc. Hopefully it helps someone who might be thinking about buying that board.
  3. DanCorcoran Minister of Fire
    Richmond, VA
    Strange. I bought the Imperial stove board at Ace Hardware and it does have an r-value. In fact, it has "Micore" stamped repeatedly on the back of it. Maybe they've changed the product. The enclosure states that it can "be used in place of one layer of 3/8 asbestos millboard". I called Imperial Group before I bought it and they said that it has an r-value of 1.09. The product number on the ULC label (Underwriters Labs Canada?) says 77Y9 Heat Shield.
  4. jankdc New Member
    The one from Lowes does not have microcore stamped on it. It does have 77Y9 on it though. In the instructions, it said that it did not have an R rating. So stick with the one from Ace if you want insulation.
  5. BrotherBart He Who Moderates
    Northern Virginia
    Yeah that is weird. I own two large and two small ones and they all have Micore in them.
  6. pen Super Moderator
    N.E. Penna
    Just bought 2 this year from Tractor Supply that had micore in them
    Only thing I suggest is that when purchasing (if you care about aesthetics) ask the person at the register / manager if necessary, if it's OK to open the box to inspect prior to purchase.
    I bought 4 before getting 2 that were without dings / bangs even though the exterior of the box they came in was pristine.
    pen
  7. begreen Super Moderator
    South Puget Sound, WA
    OK, I deleted my post, it was incorrect. Something is definitely fishy. The listing clearly states:
    Steel over mineral board for excellent protection.
    jankdc, what do you see on the backside of the board you got? I'm wondering if this is a documentation error.
  8. jankdc New Member
    Begreen, it iooked like mineral board to me. Also, I was at Tractor Supply and yes they had type 2 from Imperial.
  9. EatenByLimestone Minister of Fire
    One imperial board I saw at true value this summer had an r value of zero.
    Matt
  10. begreen Super Moderator
    That R-value of 0 seems unlikely with mineral board back there. But if the claim zero, then it is for ember protection only hearths. We don't have any Tractor Supply stores or I would check this out.
  11. mattjm1017 Feeling the Heat
    Corapeake NC
    My local Lowe's sell two one is for ember protection only and the other is an actual r rated hearth pad. I bought one thats r rated 1.5 from Lowe's its an imperial stove board.
  12. jankdc New Member
    I was at another Lowes this weekend and saw a hearth pad that had type 1 on it. It was the same that I bought, but I guess with a newer packaging.
