Lowe's Selkirk Supervent Installed
MrKenmore
66
So I completed my Supervent install this weekend. I have a Jotul Oslo that was going through an 8 inch class A chimeny above the ceiling and through the roof. I finally replaced this with the Selkirk Supervent setup from Lowes. I thought the quality was good. I recommend you check all contents prior to purchase as the chimeny pipe can get dented easily. I purchased the flat ceiling kit and three lengths of 3 inch pipe. I of course grabbed a 10% coupon from the web. This made it quite affordable. The whole package cost $355 with tax. The roof flashing had the slots at the top which I wasn't thrilled about. I know Simpson does it differently (no slots, just gaps the top). I wonder if there will be any leakage in a hard rain. The roof pitch is about 4/12 so it shouldn't be too bad. I gave the top of the storm collar a bead of hi temp silicone.
Nice job. Doesn't the code require a exterior roof brace support of some sort when above 4' on the roof?
I just thought I would mention it.
Mike
No he is good since he only bought 9" of pipe. what is sticking out of the roof is all done with smoke and mirrors.
looks great and if you got the same kit I did then your cap has no screen in it to clog up
WOW can you give me some help on how you did such a nice job installing the flashing? is there sealer uunder it? how you get the shingles all over it all nice liek that?
Thanks for all the nice comments!!! The instructions state that you can go 5 feet above the roof unsupported (guy bracing). I am at about 6 feet which includes the cap. It's pretty stable. The wood stack is my holzhaufens. That's a technique of stacking wood I found on the web and here at hearth.com. It fits a lot of wood!! Each is about 5 feet in diameter and 6 feet tall. I did try a 6 foot diameter but that had a collapse so I went down to 5. My neighbour is a roofer so he helped me do all the flashing and the shingles. Everything laps very nicely. There is some roofing cement between the flashing and the roof sheathing (only at the top). I told my neighbor, "Wow, you make this look easy!!" He said, "Roofing is simple. That's why I do it. Over, under, over, under, over, under."
Your install looks just like mine! Only cleaner....
The roof flashing won't leak in the rain....I did mind and we have had some downpours with no problem...
thanks guys! did you guys use nails to secure your flashing to the roof or screws? adn did you put any sealant under the flashing itself?
clutch25-How funny!! Right down to the high temp silicone.
greythorn3-I used nails on the top. On the sides, I nailed at the edge so the head would hold the flashing in place. There is roofing cement between the flashing and the roof sheathing.
Hi Guys, can you post pictures from the inside? What type of stove pipe did you use? Brand?
I'm planning to use the same Selkirk kit that Lowes sells but will be using Simpson single wall stove pipe from Home Depot, I'm not sure if I'll have trouble in the conection of the Simpson single wall to the Supervent stove adapter.
Thanks... Valentin
I actually like the metal fab brand pipe for the inside. I will post pics when mine is all up. I had to order some new parts.
Thanks... Valentin
Here are some inside pictures....
Thank you Guys.
Great pictures Clutch, I was trying to figure out how is the ceiling support and Flashing installed. BTW the stove piope you installed isn't upside down? I mean that the crimped isn't suppposed to point down?
Thanks for your help, again...Valentin
Valtar said:
Thank you Guys.
Nope...it just looks like that. The black pipe is double walled stuff from Menards but it is selkirk too.
The whole install is per the directions to the letter...save for a bunch of cussing and dropped screws etc...
http://www.selkirkcorp.com/Flash-Installation-Guide/english/supervent/supervent.swf
Another Selkirk Install....Seems like red RTV is in vogue this season...LOL. I better head back to caulk gun driving skewl, tho. Ya'll be much neater!
great pictures guys!!!! when i installed my on demand hot water heater for the exhaust i used a clear high temp silicon home depot sold and it looked allot nicer then the red stuff.. check it out next time your shopping its right by the redish orange stuff..
Ray
I've got some mega time built between me and the high temp copper RTV....good stuff....
I appreciate the info but couldn't have cared less by the time I got mine installed...got everything up on the roof and had to run back to Lowes with a bad section of pipe...during rush hour...NOT HAPPY!
??? Rush hour in ND ???
Was there really 3 cars at the stop sign, or are you fooling with us? ;-P
I'm thinking Fargo or Bismark.
Yep, Fargo....
You are about on point for the "rush hour".... We have it pretty easy for traffic around here!
Lots of rain here and no leaks. Very pleased!!! Monday the last parts for the interior single wall black pipe arrive. Wish I could burn this weekend. Oh well.
man i wish my shingles could look that good, i went to the home depot and couldnt find the clear this time, so will probably be using the same stuff u got since i already got a tube of that.
Ray
Those other two roofs look really good!
Mine is a joke! 3 layers! I could kill the idiot who thought that was a good idea!
what do you mean 3 layers?
Well, my shingles are only a month old. Lots of hail damage around here. Insurance companies don't bat an eye at hail damage claims here.
