Ive had my Regency F2400 for a year now and so far so good,good heat ,clean glass,S.S.liner inside looks good ... ..What I would like to find out is what is the highest temp that this stove can handle safely.....Ive looked threw the manual but cant find anything on max operating temps....The high end temps that I get go from 600 at the stove pipe using a Condar magnetic before adjustment and using a Condar Inferno stove top thermometer it has been 650 before I adjust,, from there it will do a slow slide to 550 and stay for a while as it burns down and loses heat....Of cause if one is high the other is low and vise-versa .....Im really not worried about a over-fire as I keep a eye on the temps and adjust as needed but I would just like to know if someone knows what the max temp for this brand of stove could be .I have been reading most of the post so far on temps and the different stoves have varying max temps...BTW I also use a IR laser and the Condars are off ,,slightly higher than IR, the stove top therm being closer to the IR reading than the stove pipe therm.... Well thanks for any input...Happy Thanksgiving .Keep the fires burning......Mario in Va...
