    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. joescho Member
    Northeastern PA
    Is the correct igniter part number SRV7000-647 (300 watt - pellet only)
    or SRV7000-462 (380 watt)?
    Looking to have a spare and want to make sure I get the correct part. I have the AE insert. (2011)
    I was also thinking when I pull the unit in the spring for cleaning I would also pull the convection blower and clean. Does that housing gasket need to be replaced when pulled? I think that is SRV7000-332.
    Already have the combustion gasket.
    Thanks
    #1
    Helpful Sponsor Ads!
  2. john193 Feeling the Heat
    Southeast PA
    No need to replace the gasket. The new igniter was designed for longer life, and from the research I have done there was no compromise in performance.
    smoke show likes this.
  3. smoke show Minister of Fire
    Pittsfield, Wi
    my freestander doesnt have a convection blower gasket.
    edit- I think your confusing the comb blower housing gasket for a convection blower gasket.
    your convection blower should not have a gasket unless something changed.
    Defiant likes this.
  4. john193 Feeling the Heat
    Southeast PA
    You are right, no gasket on the convection blower. I misread "combustion" blower.
  5. Defiant Minister of Fire
    Old Lyme CT
    He knows his chit:p
  6. smoke show Minister of Fire
    Pittsfield, Wi
    mostly just full of it...
    Defiant likes this.
  7. joescho Member
    Northeastern PA
    But those numbers are the correct ones for the igniters?
  8. smoke show Minister of Fire
    Pittsfield, Wi
    Defiant likes this.
  9. Defiant Minister of Fire
    Old Lyme CT
    A man of many words:cool:
