My Long Winded review of the new Woodstock Progress Stove
fire_man
2,707
North Eastern MA
I spent lots of time poking and prodding the new Progress during the pig Roast open house. Not only did I enjoy the food, beer and people, but I made a nuisance of myself asking lots and lots of questions.The Woodstock team was unfazed and happily educated me (especially Lewis, he was unbelievably knowledgeable and friendly).
Here are some of my findings – some objective others not so objective:
1. Firebox size
I brought 16†splits of cottonwood (nice and light) to see how much more wood the new stove can fit relative to my FV. The milk crate full of wood in the picture is exactly what fit in a Fireview, right up to the top. The rest of the wood is the difference you can fit into the Progress. It was a little tricky, since the progress technically takes up to 22†splits. The new stove could actually fit a couple of 16†splits vertically (that’s right, standing up in the firebox!) The tallest point was 16.5†in the front and sloped lower towards the rear. The E/W direction was 23†max just above the bottom of the door. The N/S direction was 15†max. I was told you can stack right up to (but not touching) the stainless steel baffle plate. You just need for the holes to be able to “breath†for the secondaries to work.
I was a little surprised the firebox did not fit even more, but I suspect using full 22†splits would have better utilized the extra space.
2. Construction
What can I say. Very typical Woodstock-like. Lift the cat lid and you are facing ENORMOUSLY THICK cast iron parts. I did not bring my calipers, but the steel castings and brackets were ½†thick in places – no signs of skimping.
What I really loved is there is VIRTUALLY NO FURNACE CEMENT in the entire stove! The only place it’s used is to hold in a small soapstone brick just below the door. The stove is a “sandwich†construction of exterior Soapstone panels, a welded steel firebox, and soapstone bricks lining the firebox. All of the soapstone bricks in the firebox (except for the one below the door) can be removed and replaced simply by tilting them into the firebox at the bottom of each brick, They are held in by a thick cast iron ridge at the top of the bricks.
The outer soapstone panels are a thing of simplistic beauty. You only have to remove some tiny screws that hold cast iron trim into the steel box, and each soapstone panel can be easily removed. They demonstrated it in front of my eyes. You could probably gut each and every piece of soapstone from this entire stove in less than 15 minutes with nothing but a small screwdriver. This will make repair very easy, unlike the FV which requires major deconstruction to replace soapstone panels.
The other advantage to this construction is that the stove can be brought up to a high temperature MUCH FASTER than with the cemented FV. The Soapstone panels have lots of room to expand, they are not “locked†in place so stresses are greatly relieved.
Hey Woodstock, how about disassembling the stove for us weaklings that can't easily move 700 pounds and shipping the soapstone panels in separate boxes with good installation instructions?
The thermal shock of starting up a fire in a cold stove is first absorbed by those relatively small and numerous soapstone bricks, and then transferred to the welded steel firebox.
The gigantic stainless steel baffle plate acts like a parabolic dish of sorts and directs/reflects heat very quickly after startup thru the glass – I was told it actually starts to throw useable heat faster through this huge window than does the Fireview from a cold start.
Air Contol:
There is a “butterfly†valve in the rear of the stove that simultaneously regulates primary and secondary air. It’s a horizontal shaft stretching across most of the rear of the stove, and has three blades or “vanes†(Outer primary, Inner Primary, center secondary). The primary vanes can be snuffed completely closed for long burns, but the secondary vane has a built in slot so that the secondaries always get some air. There is also a primary entry point somewhere in the front of the stove to always provide a small air supply, intended to reduce/eliminate backpuffing, especially whent the stove switches from catalytic to non/catalytic burn modes. The knob that controls the butterfly valve rotates a total of 90 degrees from fully snuffed to full on. It was not labeled with numbers on the stove I saw, but final production stoves will be.
I will probably think of some more stuff to post , but I already got kind of long winded. Bottom line, I placed a deposit on the stove and now I am in wait mode.
Great meeting you and great overview.
pen
Thanks for the review and details!
You are right that the longer lengths of firewood would make a big difference. Consider that is you us 22" splits instead of 16", that is a 35% or so increase in firewood volume. Add to that the extra splits, and you probably have 60-70% more pounds of firewood capacity. That can make a big difference.
So the stove really is a steel stove with panels of stone sort of added on. Similar to the PE alderlea stoves that aren't really cast iron but look like it?
I have to admit that it would be nice to be able to replace the stones easily.
Thanks for the review, sounds like a great stove. It's going to be an exciting Winter for all you new BMF owners. Keep us posted.
Nice review on the stove, and Thanks much. Very encouraging to read about the lack of cement in the construction of the stove, and the ease of potentially changing out any of the soapstone segments. That is a heavy stove. I would probably have to re-enforce my floor to handle the weight.
The name still bugs me.
Just name it the Prius and be done with it. If nothing else, every Toyota owner in America would order one just because.
Tony,
I didn't know you put down a deposit. Congrats! I guess that's why you kept saying you were gonna leave, but were still there.
Nice write up.
Nice to meet another Somers, NY native too.
Norumbega said:
Not long-winded at all--exactly what many are really curious to know. Thanks for your nosiness.
Not even close to being long-winded.
I personally think every post made here should be at least that long... even if you have to say the same thing over and over and over and over and over and....... :red:
Great review Tony and congrats on the new stove! I really love how that stove performed too! Wonder how many stoves were sold during the open house.. Guess lots of people are viewing my little Progress Hybrid videos as Youtube wants to know if I want to add ads and get paid for it lol.. No I didn't do that and I am sure the excitement will die down soon plus the reason I posted them was for people here to see what I saw there.. Hope to see you and TJ again next year!
Ray
Thanks, Ray - I was really into spilling everything I learned about that stove.
TJ has been excited for the new stove since they announced it - chip off the old log!
It was great to finally put Hearth.com faces to names. Last year was nowhere near the same hearth turnout.
I'm glad I finally got to meet Raybonz in person!
Thanx Tony! I look forward to seeing your new stove installed! What color and options did you decide on?
Ray
Tony, I could not have gave a better review. Thanks for posting that and congratulations. Now what we'd like to see is a review on the wood that someone took to Woodstock and I hear you had a hand in that somewhere.
Dennis:
There is an underground test lab currently evolving to test that wood of yours - stay tuned! :coolgrin: . There will be more to report at a later date. Suffice it to say your wood is the hardest, oldest, tuffest wood I have ever split. I am still recovering from the experience - I feel sorry for your hydraulic log splitter and if I was that log splitter I would refuse to ever start.
Ray:
I am still undecided about the options for the stove. It will depend on clearances to be announced. If the standard 10" leg version does not require hearth modifications relative to the FV (which I am told is looking good) I will go for that one. The 10" model requires me to change my flue setup to accommodate the taller exhaust profile.The Plinth base will most likely require a major Hearth upgrade to deal with higher floor temps- but it will not require flue modifications. Color wise, charcoal black cast iron. The other benefit to the 10" model is that it will be available much sooner.
fire_man said:
Dennis:
Ray:
If you get the legs, will you also get the ashpan? BTW, good choice on the charcoal, that was my choice as well.
I would not get the ashpan. I have been perfectly happy without the ashpan on the FV. It's one more part requiring a gasket is the way I look at it. I suppose I could be talked into it if I heard a compelling argument, but I have heard more complaints about ashpans than complains about no ashpan. I like the idea of all those coals staying near the wood for faster relights. I think the ashpan tends to cause the coals to dissipate faster - which might be good to burn them down quicker, but bad for keeping the coals hot.
having had both with and without ashpan, I would never go without an ashpan.
When you try to shovel out ashes from a hot stove, no matter how careful you are, the warm ashes go flying all over the place as you try to slide it off into the bucket.
With an ashpan, you pull it out-empty into a bucket outdoors and you avoid having ash dust flying all over the inside of the house. Since you only empty every couple of days, the gasket will last for many years.
We had a Verment Castings Encore for over 15 years and never had to replace the gasket.
I finally solved the "warm ashes flying all over the house" problem. I bought a tall bucket with a tight fitting lid from one of those on-line hearth stores. I shovel warm ashes into the bucket and immediately place the lid on top for a couple seconds until the ashes settle, then get another shovel-full and repeat. No more mess and it really works!
I view the ashpan as one more thing to go wrong, I guess it's stove dependent but I have read many reviews of people that swear at the ash pan, but few reviews of people who hate not having one.
On a side note: I can't wait to be able to review the operation of the Progress. Word has it my stove should ship next week.
Look forward to hearing your experiences and pics!!
Ray
I solved it a different way... I installed a 2nd Fireview. Let one go cold, clean ashes, re-fire. Do the same with the other when needed ;-)
I do like to have both heating when it gets below 0F. On those -20F windy nights it's really nice.
Here we go again. I began my life with wood stoves very early in life. Being only around 5 years old or so (don't remember exactly except that I was in kindergarden), I was a bit small for splitting wood or even carrying much. Besides, I had polio so was a bit of a runt. So, my first chore with the wood stove began with cleaning ashes from 2 heating stoves and 1 cooking stove.
Being young and wanting to help I was perhaps a bit overanxious and worked quite fast. I was so proud....until mother called. My second job was to dust the entire house because I had gotten ash dust all over the place. That was not so much fun. So I very quickly learned the proper method of emptying ashes. All we used was a small shovel and a galvanized bucket. So how do I dump the ashes without making a mess? That turned out to be very easy and anyone can do it.
The key is to work slow. Make your movements slow and never overload the shovel. Then you gently put the shovel into the bucket....but DO NOT DUMP THE ASHES FROM THE SHOVEL. No, you sit the shovel down gently and then very gently slide the shovel out from under the ashes. Yes, there is a difference. Remember to never dump the ashes off the shovel. That folks is all there is to it. No ash dust at all if it is done right.
Our present stove is our first one that does not have an ash pan. We were a bit concerned but now having it we love it and would never look for a stove that has an ashpan. In fact, we have a new one on order and it comes with or without the ashpan. Ours will be without.
