I'm burning mostly hardwoods here keeps good heat . I've been able to keep the house in the mid 70s since we started using the new stove
What were you burning, gasoline soaked rags? LOLShould've took apic of the wild fire I had in my stove . Took the flue up to 1200* from 200* in like 15 min stove top was 450* when I shut it off , lost secondaries but wow it was getting hot quick . Secondaries started right off the bat 5 min into the fire and everything was charred good when I shut it down , scary
Ignore the stove top temps and use your eyes to determine when to start closing the air. When a stove is starting a reload or even a fresh load of dry wood it needs to be checked every 5 minutes. 15 minutes is too long to take your eyes off of a fresh fire.
I did that this morning and had the stove turned down within 15 min after reload as it took off quick again . White oak is what I'm burning right now. I've been putting in 2 big splits and same amout if small and medium splits . It's not so much the stove top as it is the flue that gets hot fast
