    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. John59 New Member
    I have a Napoleon stove that has given me problems since I bought. I bought it used, I took it apart and cleaned everything. I can't get it to burn more than a day without the pot overflowing. It has to be emptied everyday. The glass also gets black in a few hours. I replaced the door gasket, changed the piping, and replaced the combustion motor. I also have tried about 5 different brands of pellets with the same results. Does anyone have any advice on this problems?
    Thanks John
    #1
    Helpful Sponsor Ads!
  2. jtakeman Minister of Fire
    Northwestern CT.
    NPS40 or NPS45?
  3. John59 New Member
    NPS40
  4. jtakeman Minister of Fire
    Northwestern CT.
    More air might help. Try opening the damper. We have a member save$ who owns one. Hopefully he chimes in with his advice for you.
  5. DexterDay Minister of Fire
    NE Ohio
    Have you cleaned EVERY single little passage?? (Meaning you know how the air gets from burn pot to Combustion blower)?)
    Sounds like a blockage somewhere? Save$ has one and his only likes certain pellets. But IIRC, he can go at least 3 days without touching the pot.
  6. John59 New Member
    I think I have gotten every passage. I also have tried every combination of air settings.
  7. jerico54 Member
    Northern Maine
    Silly question...have you slowed down the auger feed?
  8. jsvo Member
    vt
    where are you putting your setting. auger feed ,air rod? is your ash pan sealed tight ? what does your flame look like when it is running ,and how long before your pot is full. i have run one of these stoves and they are not the easiest to get adjusted compared to many stoves .do you have an oak hooked up
