    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Justin M Member
    Southbury, CT
    I'm looking for something to replace the flexible twisted wire brush that came with my Accentra insert. The rod that the brush is on has become too flexible, and when I attempt to clean the left exhaust passage it binds up before I can get it all the way in. Is there something better that I can replace it with?
    #1
    Helpful Sponsor Ads!
  2. Cincinnati Kid Member
    Cincinnati
    I have the same problem and would be interested in what others suggest
  3. Delta-T Minister of Fire
    NH
    I would suggest reenforcing the brush you have with a metal coat hanger or something similar...its cheap and fairly easy.
  4. SXIPro Feeling the Heat
    Northern MA
  5. Justin M Member
    Southbury, CT
  6. SXIPro Feeling the Heat
    Northern MA
    Probably right. I have two of the real Harman ones tie wrapped together, since one is so old it barely has any bristles left. :(
  7. Tim_M Member
    Halifax, NS
    I use a cleaning brush from the Dollar Store with a straightened coat hanger securely fastened to the end. It is plenty stiff and can easily reach to the top of the exhaust passage on my Invincible.
  8. iceguy4 Feeling the Heat
    upstate ny
    go to a plumbing outlet...get a "boiler brush" all different kinds
  9. Justin M Member
    Southbury, CT
    So I reinforced the wire brush with a wire coat hanger taped to it and it still didn't work. It just folded like a pretzel. The first time that I cleaned the stove the Harman brush worked fine. The second time it was a little harder. The third time and since it has been impossible to push the brush in the last 6 inches. I wonder if I have a blockage and the tool is not the problem. I don't see why that would be the case though since I use quality pellets, clean the stove regularly, and don't have symptoms of a blockage that I know of.
  10. Big E New Member
    Upstate Panhandle NY
    I went to a hardware store and bought a brush in the welding section. very strong as the metal part is three twisted pieces twisted together. I opted for nylon instead of metal bristles.
  11. Bioburner Minister of Fire
    West central Mn
    If you have a farm supply checkout the dairy section for inflator brushes.
  12. lecomte38 Member
    Central Mass
    How much does the oem Harman brush replacement cost? Same boat. Mine still goes thru but the bristles are getting sparse.
  13. Lousyweather Minister of Fire
    America
    eh, the brushes arent that expensive......get a new one, and clean the tube more often to minimize the deposits your are moving....might make it easier?
  14. Justin M Member
    Southbury, CT
    The price is not the issue. I have a new brush on order. The issue is that the brush just isn't stiff enough. I have used it 4 times over the course of 2 ton of quality pellets. So, the stove should be plenty clean, and the brush should not be worn out or compromised. I am going to cut the handle end off of the original brush and try putting my drill on it to see if it helps.
  15. ironpony Minister of Fire
    mid-ohio
    Grainger tubing cleaning brush. any dia, length, bristle type you want.
    I have several for the different tube sizes, Get one alittle bigger in dia and it will really scrape the ash out.
  16. glenc0322 Minister of Fire
    long Island NY
    when you clean out the heat exchange tube on the left (when you are facing the stove) do you look in the right tube to see that you are going all the way. its possible that you never went all the way in the first place and like you said there could be a blockage i made a hose for my vacuum that is 3/4 in and long enough to go all the way through the left tube after i brush the tube i vacuum it out.
  17. Justin M Member
    Southbury, CT
    I ordered a brush from Grainger, but unfortunately it id on back order.
  18. ironpony Minister of Fire
    mid-ohio
    look in the catalog and pick another, when I was looking there were many with the same sizes. or ask the guy to cross reference it
  19. Justin M Member
    Southbury, CT
    Yes, I visually verify that the brush has gone all the way through. The first 2 times I got it all the way, now the brush binds up and bends with in the exhaust passage about 6" from the end.
  20. glenc0322 Minister of Fire
    long Island NY
    you might have a blockage you can try fiberglass snake just to make sure you can get all the way through and shine a light down the right tube to make sure its all the way through if it goes through move it around and then try the brush again if you still have no luck with the brush then at least you know its the brush and not a blockage. i believe if it was blocked you would have unbalanced heat coming from the top vent.
  21. rickwai Member
    ohio
    The best way is to take the hard plastic end off the shop vac hose and the hose will push all the around the corner and you can see it in the back corner through the right port.It sucks the ash out as you go. Then run brush in to clean the corners of the tube then shop vac out again. This is how I clean accentras. I clean 20+ a year and it work like a champ everytime. Brush should last forever w/ this procedure, usually you dont even need to brush. Hose is about the prefect fit for the square tube. Sometimes you have to work it back and forth if you hit a tough spot.
  22. glenc0322 Minister of Fire
    long Island NY
    go to the search topics and put in Shop vac attachment
    this is an idea that a member made close to what I am using
  23. Justin M Member
    Southbury, CT
    That's a good idea, I think I will try that. My shop vac hose is too big to fit in the exhaust port so that would be perfect. It would also help to clean out the exhaust chamber under the combustion blower.
  24. glenc0322 Minister of Fire
    long Island NY
    thats what i do every time takes an extra 3 minutes but i know its clean. I clean the whole stove every sunday
  25. Tim Linden New Member
    I clean mine every Sunday too! LOL Fire + Football day for me
    glenc0322 likes this.
