Need Help
lighterup
4
Springfield MO
I'm needing help finding safety specs to install a wood stove... file attached... the company went out of business 2 years ago and the spec plate on the stove is to bad to read... I've searched online I've called everywhere and even checked all local shops... It's installed with double wall 8in black pipe from stove to chimney pipe... but I need to know how close to the wall I can safely be cause the corner is 6in from hardey backer board... plus I need specs for insurance.
Kindly
Joe
Could you share a front picture of the unit?
From doing some searching it sounds like it could be a silent flame stove? Does it say that anywhere? This company made stoves under that name, however, none with that model number.
I can find a manual for the 1661 and 1662 but not for the 1653 like you have.
Unless you can dig up something that I can't, this thing is going to need to be installed by NFPA 211 guidelines,,, if that is OK with your insurance company.
In general, clearances for this were 36 inches, but could be reduced with wall shields that are non-combustible and were left with a 1 inch air space behind them (screw to the wall but use a 1 inch piece of pipe behind the shield going through each screw, or strips of backer board to keep it off the wall). However, I'm not sure exactly what the specs are for a corner installation are without looking them up,,,, but it'd be best to make sure that installing by NFPA 211 guidelines is OK with them before putting much effort into things.
If the corner is 6 inches away from that hardy and the shield now, and both are sitting directly on top of the paneling, then it is NOT safe to operate the wood stove,,,, as that is far too close. There needs to be spacing between the shield and the wall, and even then, 6 inches may be pushing it.
Good luck,
pen
Reactions: tfdchief
Good luck,
pen
WOW Mod you told me more in 5 min than all my research in 5 months! LOL
I was hoping not to call my insurance company yet but I was hoping to put hardy backer and either tile or rock in the whole corner... or maybe if they make double wall 8in flex elbows? I could come away from the walls and just cover the floor.
Also is it possible to repost elsewhere on the forum to reach out to other experts... :)
Post right here. Ya get'em all.
