Hello
This AGA UK multi-fuel stove boiler is really neat and looks good too! Has anyone seen it running?
http://www.hotprice.co.uk/aga-minsterley-multi-fuel-boiler-stove
Aga Minsterley Multi-Fuel / Wood Burning Boiler Stove
One of the largest stoves from Aga, the Minsterley not only provides central heating but also generates a plentiful source of hot water for your home
With a nominal heat output of 7.5kW to water (and a maximum output of 11.2kW to water)
The Aga Minsterley features a thermostatic (water temperature) control as well as primary and secondary air intakes for optimum control
Its versatility means that as well as burning wood it can also burn coal, peat briquettes or smokeless fuel through the use of the interchangeable wood burning plate
Combining the power and efficiency of its heat output, the Minsterley is the perfect choice for the family home
Reciprocating grate for solid fuel
Top or rear flue outlet option
Overnight burning capability
