Newbie with fisher baby bear and englander 24? and questions.
iceisasolid
110
North Central Idaho
Greetings,
I have been reading this site and have some questions if some would answer.
I recently moved to the snowy intermountain west and decided that country living is for me. My home was previously heated with a wood stove and I am planning on returning it to its former glory due to recent power outages leaving my home (1800 sq ft) cold for 8+ hours. I have a smaller guest cottage about 600 sq ft. I have been reading about wood stoves and have one in the guest home- soap stone type- which burns out after 6 hours.
I ran across a Fisher Baby Bear for $225 and an Englander 24-fc124-ac (has the blower) for $275. I have been reading about the Englander stove but cannot find specific info on this non-glass door model which has a horse shoe on the front. Both stoves are in pretty good shape with no rust in the Fisher and minimal surface rust on the Englander. My uncle has a similar model Englander that has a 14+ hour burn time.
As I read more about stoves, I am concerned that I may have acted too rashly due to EPA ratings. I plan on the the Fisher for the guest home and hope to get 8+ hours of burn time out of it.
In regards to the Englander, are there restrictions that I should be aware of? I have buyers for both stoves should they not pan out as I would like.
Any advice would be appreciated.
learned a bit about these stoves today. Mike at England Stove Works was gracious enough to entertain my questions.
Lessons learned:
Englander 24 AC- decent stove heats to 2200 Sq Ft and meets EPA guidlines- built in 1991 (its in pretty good shape too).
Fisher Baby Bear- probably will need to wait for my equipment shed to be enclosed or my garage to be enlarged.
I have an 1980's model Heartstone II in my guest cottage that will probably work better that the Fisher for its purposes- its installed currently.
Biggest problem now is the cost of new prefab chimney pipe for running up the house from the main floor through the roof of my 2 level home- at about $90 per 3 feet and the cost of the T box for outside plus install. Any leads on a reliable wholesaler of stove pipe? It is going to out of the wall to outside and then through the roof via the soffet. Any help would be appreciated.
-IIAS
after reading more about pipe installs, I am considering placing the chimney pipe in the house and running it into a seldom used closet out the roof in the second floor and through the roof for an inhouse pipe. Better drafting? More efficient? Less smoke in the house? Heck, I am a bit confused about the "right" install. Any advice? Any?
