Woodcutter Tom
The manometer that I and others here use is the Dwyer Mark II Model 25. This unit provides the proper scale for the draft range that stoves utilize. I purchased mine on ebay a year ago. I checked there and am surprised (shocked) that the price is over double of what I paid. There seem to be many previously used units and some new available. I would look very careful at what is included in a used unit. A complete new unit includes the unit, special oil, tubing, fittings, and instructions. I used a 4 foot section of 1/4" copper tubing to connect to my double wall stove pipe. You need a section of this to keep the heat away from the rubber tubing in the kit. I drilled a 1/4 inch hole thru both layers of the stove pipe (at the rear so it does not show). The hole is located about 5 inches above the stove top. I pushed the copper tube thru the hole until it is inserted about 1 inch past the inner layer. The other end is attached to a 12 inch section of the tubing that comes with the unit. I used shrink wrap for this connection.Interesting! I'd certainly want to measure that. Any information on where to get a manometer and how you're connecting it to read draft?
How big of a house are you heating with it? I can't imagine how small the 1500 is. I'm finding the 1800 really small for loading...I can only get 3 big splits in there and I'm always hitting the damn air tubes when I load it.
If I load it up at 11pm, I barely have coals at 5am.
My house is a 1200 square feet ranch. I almost exclusively load my stove N - S (front to back) I have splits cut at 11" long. I can get a lot more wood in my stove loading that way. On a reload at night, I may scrape the coals either to one side or to the center. Then I place splits on the cleared areas and on top of the coals. The fire will burn where the coals are and then work its way toward other areas throughout the night.
![Not getting enough heat - New Drolet 1800 - Do I need a flue damper? Not getting enough heat - New Drolet 1800 - Do I need a flue damper?](https://www.hearth.com/talk/data/attachments/291/291648-e92ab6c7a3344754597274409a8b9e99.jpg)
