Did the exact thing with my 360 on Thursday. I missed the "burp". Pulled and pulled like crazy flooded it and just got it running today. Keep the saw and get used to it.
north of 60 said:Its a piece of mechanical equipment, S_it happens. Gig deal. Its still a top end saw. Sometimes your shoelace unties and you trip on it. Do ya throw your good shoes out?
KYrob said:I sawed all day and busted up a lot of wood with the super splitter axe. Gonna be sore in the morning. Saw ran great and started up with one pull after it was warmed up. Think I'll hang on to it.
Rob
Rob
John_M said:My Stihl MS250CQ is less than one year old and has cut 3-4 cords of firewood. It has been an excellent saw for its intended use. The Quick Start feature is a marvel of engineering. I have nothing but praise for its performance, startability, and reliability. Best wishes, John_M
Nonprophet said:John_M said:My Stihl MS250CQ is less than one year old and has cut 3-4 cords of firewood. It has been an excellent saw for its intended use. The Quick Start feature is a marvel of engineering. I have nothing but praise for its performance, startability, and reliability. Best wishes, John_M
I had one of the MS250CQ's, hated it! I bought it used off of CL from a weekend warrior who rand one tank of gas through it cutting down two trees in his backyard--it was in near mint condition. The EZ Start feature really sucked IMHO, ironically making my MS250 EZ start the hardest to start out of all my saws! I dumped it quickly, and I'm glad I did.......
NP
webie said:Actually I had one too but couldnt pass up the 175 I made on selling it . I figured out how to start it after I showed my 110lb sister how eaasy it was to start . Its not a drop recoil saw or a fast recoil saw you need to pull it slowly is the best I can explain , then it works great .
Actually my 84 year old mother could start it toosmokinjay said:webie said:Actually I had one too but couldnt pass up the 175 I made on selling it . I figured out how to start it after I showed my 110lb sister how eaasy it was to start . Its not a drop recoil saw or a fast recoil saw you need to pull it slowly is the best I can explain , then it works great .
lol with a 440 mag heck yea! but your sister?
webie said:Actually my 84 year old mother could start it toosmokinjay said:webie said:Actually I had one too but couldnt pass up the 175 I made on selling it . I figured out how to start it after I showed my 110lb sister how eaasy it was to start . Its not a drop recoil saw or a fast recoil saw you need to pull it slowly is the best I can explain , then it works great .
smokinjay said:Nonprophet said:John_M said:My Stihl MS250CQ is less than one year old and has cut 3-4 cords of firewood. It has been an excellent saw for its intended use. The Quick Start feature is a marvel of engineering. I have nothing but praise for its performance, startability, and reliability. Best wishes, John_M
NP
ApproximateLEE said:REDD u just commyitted one of the wurst cardnal sinns. Menshunning pullon and STIHL in the same sentance.
A good quick cure for a flooded saw is a butane/benzene torch in the cylinder head for 2 seconds to burn off the gas, and warm the plug while your at it.
John_M said:Starting instructions in the MS250's owners manual are not the best. Here is how I start my EasyStart MS250 after it has not been run for a few hours or months: 1) If needed, squeeze the primer bulb 1-4 times; 2) Set choke to full on position; 3) GENTLY pull starter cord until I feel compression; 4) Using the same technique as in #3, GENTLY pull starter cord another time or two until the "burp" is heard; 5) After hearing the "burp", lift choke lever to the half choke/start position; 6) GENTLY pull the starter cord another time or two until the saw starts. Using your strength, power, and speed to start the saw will not work. Use those manly efforts on the bigger saws without the Easy Start feature. Let the spring activated starting mechanism fulfill its intended purpose-allow IT to start the saw
A buddy tries to start my MS250 Easy Start the same way he starts his older "Farm Boss" using the "drop and yank" method. Neither he nor I can start my MS250 that way. Yanking away on the starter cord is not the proper way to start a saw with Stihl's Easy Start feature, even though another Stihl dealer showed me the "yanking" technique before I purchased my saw from a different dealer.
This information is humbly offered only for those who might be interested. It works for me. It might/might not work for you. Best wishes, John_M
