oval flex liner, round brush?
kevinmerchant Posted By kevinmerchant, Aug 15, 2010 at 4:54 PM
Thread Status:
  1. kevinmerchant
    kevinmerchant
    114
    1
    Loc:
    Cheshire, CT
    I thought I had read here about trimming a round brush to go down an oval liner. If this is possible then can I use wire cutters to trim the poly brush.
  2. LLigetfa
    LLigetfa
    7,361
    110
    Loc:
    NW Ontario
    Wire cutters would work fine. When testing the fit, if you leave the bristles too long it can be a real bugger to reverse, so be prepared for the possibility that you cannot reverse it.
  3. YZF1R
    YZF1R
    181
    0
    Loc:
    Southeastern PA
    If it's too big and gets stuck, you may be able to try this. Twist it in the direction that tightens the rods together (so they don't come apart) then pull almost at the same time. Push, turn to the right, while turning to the right, gently pull. The base of the bristles will do a U-turn while the tips are against the liner wall.
    Steve
Thread Status:
