    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. area_man New Member
    Oregon City, OR
    I was upstairs when I heard the Clank and smelled something off. When I went downstairs I saw the thermometer laying on the floor and the stove at a faint orange. I immediately cut off the air and aimed a fan at it on high to try to get some heat off it. Within 15 minutes I got it down below 700. Still, I hear that magnets demagnetize at about 1000 degrees. It must have spent at least 15-30 minutes at 1000 or above.
    I didn't hear any hard clanking noises or snaps or anything that would indicate broken welds, so there's that. Anything to worry about in the aftermath? I've burned it a couple times since then and everything has been OK.
    It still holds wood and burns...
    #1
    Helpful Sponsor Ads!
  2. begreen Super Moderator
    South Puget Sound, WA
    It's easy to do. Try to not let that happen again.
  3. area_man New Member
    Oregon City, OR
    Copy that.
  4. CT Pellet Minister of Fire
    Torrington, CT
    I have A.D.D.......so this kinda thing happens weekly. Its been almost two years now of subjecting the stove to these regular "blushings" and no issues yet.
  5. begreen Super Moderator
    The Orley is a tough tank. I have seen several that have the paint whited out and they still seem solid.
  6. Wood Heat Stoves Minister of Fire
    Nevada City, California
    I would check for broken welds but other than that it's probably OK. Yes, thermometers lose their magnetizum at about 1000 degrees, that's why they come with screws so you can screw them to the pipe so they don't fall off and burn your carpet.
  7. begreen Super Moderator
    The Orley is basically a barrel stove with a picture window. It's pretty tough.
  8. drumbum Member
    mid tenn
    High carbon steel.
  9. Wood Heat Stoves Minister of Fire
    I remember they had a lot of fancy scrolls on them but behind that was just a round barrel. That wasd a long time ago. They must be tough!
