Is the room temperature probe connected? is it laying on the floor?I have a Harman P61 I have the room temperature set to 55 but the stove is making the room upper 70s and some time 82
No its not I have it about 6 feet off the floor, let me say I have cleaned it replaced room probe, esp, control panels, gaskets the stove is now in its 14th yearI have a Harman P61 I have the room temperature set to 55 but the stove is making the room upper 70s and some time 82
No pets any more and I get the same thing in stove temp.
When ? ESP controls stove feed and if it thinks it got some poor fuel or a weak fire it starts to feed high. Been a rash of ESP failures this season but usually causing a low fire. Control panels have a couple pot switches that wear and give all kinds of grief but usually the fan control not temp control. Worn leaky gaskets can allow more air into stove but not thru the fire and cools the flow out the exhaust fooling the ESP but usually not that much.esp, control panels, gaskets
so far the only gasket I have not replaced is the pellet box as I said earlier I have 4 control panels and they all do the same thing this has been a on and off problem for three years and like a fool spent too many dollars to get it fixed, esp has been replaced about three times and I have a new room censor but it does the same thing and tests the same as the old oneWhen ? ESP controls stove feed and if it thinks it got some poor fuel or a weak fire it starts to feed high. Been a rash of ESP failures this season but usually causing a low fire. Control panels have a couple pot switches that wear and give all kinds of grief but usually the fan control not temp control. Worn leaky gaskets can allow more air into stove but not thru the fire and cools the flow out the exhaust fooling the ESP but usually not that much.
I replace the ash pan gasket the problem is the stove gets to hot set at 55 and like last night I had to shut it down around 2am it was 82 in the house, the exhaust fan has never been touched nor do I know haw to do that, I am about to get another esp it seems to be a yearly thing.Gaskets are about the cheapest of any of the stove repairs. I don't know if the replacement of the ash bin gasket would improve the issue but if cold air is coming in through it and not getting any heat from the fire it could really mess with ESP. Has there ever been a manometer used to set the exhaust fan?
I've gone over every inch of the wires and have not found anything that I can see wrong with them. When I do shut the stove down I have waited 5 hours then have had to just unplug it.I miss read your last post and see the only gasket not replaced is the hopper lid.
I don't have any more ideas. If i had it in my shop I would be tearing out all the wires and checking if there was something showing wear etc.
Not to unusual if the stove is up to full operating temp.I have waited 5 hours
Yes I have it on a surge protector.The manometer reading taken at the port at the bottom of the fire box and the screw for adjusting the fan is on the board.
So you have the stove on a good surge suppressor or like many here a UPS to help protect the board?
No I haven't the wiring is from the mid 1950s, I guess I should check it.Thing is the ESP is hooked directly to the board.
Heres a wag, have you ever check the outlet for proper wiring and polarity? It pops up from time to time here in the couple years I have been trying to help with smart stoves.
