PB 105 to existing oil system
paradirr Posted By paradirr, Apr 24, 2013 at 5:55 PM
  1. paradirr
    paradirr
    New Member 2.
    NULL
    Apr 23, 2013
    3
    0
    Loc:
    Maine
    Hi to everyone on hearth.com, I am new to the forum as well as new to a PB105 boiler. I just purchased this boiler with the plan of installing it in series with my current oil boiler system. I have searched a lot around about series and parallel but I just seem to think that series may be easier. I am in no way certain that is the way I am heading but I would like other peoples opinions on it. Also I was wondering if I needed to add another circulator pump on the new system. My current is controlled with three zones on zone valves with one circulator. My plan was return of zones into return on PB then supply to return on OB then supply to zones but I am not sure if I need to be able to circulate through both boilers when water is being heated with no call from zones. Any input would be appreciated.
  2. Bill Bennion
    Bill Bennion
    Member 2.
    NULL
    Feb 2, 2009
    59
    0
    Loc:
    Lee, NH
    That is exactly how I have my PB 105 set up with oil boiler. I have been running this set up for about 4 years now.
  3. iceguy4
    iceguy4
    Minister of Fire 2.
    NULL
    Nov 16, 2011
    1,039
    237
    Loc:
    Upstate, NY
    Me too...no need to ad extra circulator...I recommend a field control vent damper on the oil boiler to help limit losses in your existing boiler
  4. paradirr
    paradirr
    New Member 2.
    NULL
    Apr 23, 2013
    3
    0
    Loc:
    Maine
    My questions is how does my water circulate when the PB is running and there is no draw for heat, for instants if the temp goes below minumum but my zones are fine? Maybe foolish question but is that ok to just fire the PB to heat water in the actual boiler? I know that the aquastat on the OB powers the circulator pump when it powers the burner. How does that work on the PB? Appreciate the input guys.
  5. maple1
    maple1
    Minister of Fire 2.
    NULL
    Sep 15, 2011
    7,073
    1,219
    Loc:
    Nova Scotia
    Not familiar with the PB - but would it just shut down with no call for heat?
  6. R Mannino
    R Mannino
    Member 2.
    NULL
    Sep 4, 2008
    89
    5
    Loc:
    Long Island, N.Y.
    How are you producing domestic hot water? Coil, indirect or direct?
  7. iceguy4
    iceguy4
    Minister of Fire 2.
    NULL
    Nov 16, 2011
    1,039
    237
    Loc:
    Upstate, NY
    the pb 105 will just heat itself ...fire at low setting and go off at high setting...no circulator because there is no call for heat.. the pb knows nothing but these settings.
  8. iceguy4
    iceguy4
    Minister of Fire 2.
    NULL
    Nov 16, 2011
    1,039
    237
    Loc:
    Upstate, NY
    I have a hot water maker on its own zone...now since boiler is off I'm back to electric
  9. paradirr
    paradirr
    New Member 2.
    NULL
    Apr 23, 2013
    3
    0
    Loc:
    Maine
    ok thanks that clears it up. I was not sure if it was ok for pb to run on its own with no call for heat other than inside the boiler. My DHW is going to be hybrid electric on its own system. Thanks for the help.
