Pellet insert and chimney air leakage
woodlecj
7
Bethlehem, PA
Hi Folks,
Getting ready to install my new Napoleon insert myself. I have a two story with a chimney lined with clay or terra cotta in great shape. The flue appears to be about 6"x10". When I was shopping for stoves, two dealers said they would just stick a 5' flex in there and stuff it with regular fiberglass insulation and two said to go all the way up the chimney with 4" flex. I decided on the full length and bought a 25' Flexvent kit. But I'm concerned about heated air leakage up the chimney as I know the insert and shroud against the hearth won't provide a very good air seal. Once I open up the damper (or remove it altogether), should I just stuff plain old fiberglass around the 4" flex in the flue?
Another question; the stove can be converted to vent either straight out the back or out the top. If I vent out the top, I won't need a Tee, but then will this be a pain later when I need to sweep the 4" flex from the top of the chimney? Should I just stick with a Tee?
Also the air intake is in the back of the insert; is this OK and will it just pull combustion air from the Living room past the insert/shrould? Should I buy a 25' freash air vent and run it up the chimney?
Thanks,
Craig
shane is correct (as usual) :) note on outside air , unless the stove is designed to allow fresh air into the fireplace do not seal the face of the fireplace so that ambient air can get in. maybe place soft spacers to cut down any vibration (there are motors and such that can make vibrations) but allow air in to get better combustion
