Pellet Stove repair
Sharon17 Posted By Sharon17, Oct 31, 2007 at 12:23 AM
Thread Status:
  1. Sharon17
    Sharon17
    New Member 2.
    NULL
    Oct 31, 2007
    2
    0
    Loc:
    Central NJ
    I live in Central NJ and have owned a Whitfield Cascade pellet stove for the last 7 years. Recently, the pellets have stopped feeding through the hopper. I am not mechanically inclined, so taking it apart is not an option. I have called dozens of fireplace shops, including Lennox Hearth Products trying to locate anyone who works on pellet stoves to no avail. Everyone I have called sells the stoves, installs them but does not do the repairs. Technical support at Lennox gave me numerous people to call, also to no avail.
    I would appreciate if anyone can point me in the right direction in getting my stove repaired. Replacing it with another $2500 unit is not an option
    Thanks.
  2. stoveguy2esw
    stoveguy2esw
    Minister of Fire 2.
    NULL
    Nov 14, 2006
    6,185
    1,102
    Loc:
    madison hgts. va
    have you checked with any local chimney sweeps, a lot of them do service work on pellet stoves, annual cleanings and such mostly , but some of them service stoves as well, ie replacing motors and blowers and such. you would want to see if they are familiar with the brand with whitfield being a common brand its a good chance they would be. find out where you might procure parts if needed if they do not have a supplier. i hope this helps ya. if you still have no luck , let me know and i'll look around for you some, might just be able to find someone who can help
  3. hearthtools
    hearthtools
    Moderator Emeritus 2.
    NULL
    Jan 6, 2006
    2,026
    32
    Loc:
    Oakhurst, California, USA, Earth
    That stove is a small Simple stove
    Not a lot of fancy stuff.
    Whitfield made it to sell in the Hardware big box store market.
    Sounds like your pressure switch is tripped. due to blocked flue or the small port the vacuum hose is connected to is plugged up.
    Pull the hose off the Round pressure switch and Blow to clear.
    See trouble shooting on my site for Pressure switch/Vacuum switch fix.
    http://www.hearthtools.com/parts/lowlimit.htm
    That stove is small and light
    When we service them I like to send 2 guys out
    they Carry the stove out side vacuum out the ash
    then blast it with a leaf blower and or Air Compressor.
    that stove uses One motor for both the Room air (convection blower) and the combustion blower
    Are you sure the blower is working because if it is not blowing the vacuum switch will not close to let the auger feed.
    We stock most parts for that stove
    http://www.hearthtools.com/parts/replacement_parts_for__Cascade_WP5.htm
    Get what you need soon
    lennox is no longer going to make parts for stoves older than 10 years old.
  4. stoveguy2esw
    stoveguy2esw
    Minister of Fire 2.
    NULL
    Nov 14, 2006
    6,185
    1,102
    Loc:
    madison hgts. va
    yep, and there he is, you da man rod!
  5. GVA
    GVA
    Minister of Fire 2.
    NULL
    Sep 4, 2006
    2,140
    0
    Loc:
    Waxhaw, NC... Formerly North shore Mass
    Pretty soon Rod is gonna have to charge admission to his site ;-)
  6. stoveguy2esw
    stoveguy2esw
    Minister of Fire 2.
    NULL
    Nov 14, 2006
    6,185
    1,102
    Loc:
    madison hgts. va
    tell me about it , i popped in a couple times and was amazed at how much stuff he has crammed in there , great site rod!
  7. hearthtools
    hearthtools
    NULL
    Jan 6, 2006
    2,026
    32
    Loc:
  8. Sharon17
    Sharon17
    New Member 2.
    NULL
    Oct 31, 2007
    2
    0
    Loc:
    Central NJ
    Thank you for your help and your replies. I have contacted Lennox, chimney sweeps, fireplace stores etc. Needless to say, I have spent the last month and a half trying to find someone who can repair my unit. Customer service at Lennox gave me a ton of people to call, some have not returned the calls, the other half have no knowledge of the Whitfield stove. Apparently, I can find people who will clean it, sell me a new one and even install one. But no one in NJ can service or repair them. I am at a complete loss of what to do. I have run through the phone book, dealers, distributors, with no luck. I would appreciate anyone's input -- Thanks!
  9. mtalea
    mtalea
    Feeling the Heat 2.
    NULL
    Dec 14, 2005
    349
    1
    Loc:
    Bristol, Connecticut
    He is the man,A real fountain of information......I was wondering what that air hose and round thing is on my stove...of corse I have a different model but sounds logical to me.Hey rod on the jamestown is it the same...if so what can I do to mine to see if all is well?
  10. Gooserider
    Gooserider
    Mod Emeritus 2.
    NULL
    Nov 20, 2006
    6,737
    10
    Loc:
    Northeastern MA (near Lowell)
    Moved to the pellet room for obvious reasons...
    Gooserider
  11. webbie
    webbie
    Seasoned Moderator 2.
    NULL
    Staff Member
    Nov 17, 2005
    12,185
    1,087
    Loc:
    Western Mass.
    This is a problem in the Pellet World - the lack of "generic" installers and servicing companies to take care of folks after the warranty expires.
    You have probably already contacted the "pellet specialists" in your area that completed the educational program?
    http://www.nficertified.org/pages_consumers/consumers-1.html
    If you run out of industry specific options, a skilled HVAC (plumbing heating type) should be able to follow Rods lead in terms or replacing your parts.
  12. pegdot
    pegdot
    New Member 2.
    NULL
    Nov 16, 2007
    415
    0
    Loc:
    Upstate, SC
    Great link, Craig. Thanks! IS there someplace you can go to learn to repair pellet stoves? Don't laugh! I'm serious! Sort of.....
  13. hearthtools
    hearthtools
    NULL
    Jan 6, 2006
    2,026
    32
    Loc:
    Check out all the Parts pages on my site. for each manufacture. http://www.hearthtools.com/parts/index.html
    Most pellet stove are about the same type of systems just a few different ways of wiring things up.
    there are a number of trouble shooting guides I wrote and some from each manufacture
    This is how I teach my guys.
  14. mkmh
    mkmh
    New Member 2.
    NULL
    Jul 15, 2007
    407
    2
    Loc:
    Southern, Maine
    This is kind of a long shot, but I think if I were in your shoes I would consider posting a free ad on CraigsList.org; seeking an experienced general handy-person or other to diagnose and repair your stove. I would be as specific as possible with the make and model of stove as well as the symptoms of your problem.
    If it were me I would request some references (and check them) and ask people to explain in e-mail why they think they are qualified to fix your stove. Quite frankly, there are lots of folks out there that could get this figured out and fixed for you. You just need to find one of them and set up some terms that are mutually agreeable.
    I would let people know that you are willing to pay cash, and that terms are negotiable. You'll have to be extremely cautious with how you manage the situation, but I think if you're careful that you could have your stove up and running by Christmas.
  15. Shane
    Shane
    Minister of Fire 2.
    NULL
    Nov 21, 2005
    1,831
    3
    Loc:
    Casper Wyoming
    There are numerous classes taught throughout the year for NFI certifications, do a search for Dave Pomroy. I just ordered the books and then went and took the tests at a local test proctoring place. I read the gas one but passed the tests for the wood and pellet without actually reading the manuals.
    The chimney sweep institute of america has an actual facility in Indiana for training as well. I don't know what they offer specifically for training concerning pellet stoves though.
Thread Status:
