As far as being safe with high heat, these stoves are made out of good thick steel. Especially ours. Mine is a 2000. It takes alot to actually heat them to a dangerous point.
I wouldnt worry too much in that aspect as long as its running right.Ex
For the lower 3 buttons being 6 1 1 they made small design changes in and around 2002 i believe.
Im pretty sure the higher lba settings on newer stoves is to account for the more and larger holes in the burn pot. Which was required to meet new emission standards.
You say you wont touch those buttons again but i was having to change the lff regularly depending on which brand pellets i burnt. Thats what the buttons are for, fine tuning.
I replaced mine a couple weeks ago with a newer used stove. Only because i couldnt pass up the deal. A 2008 enviro evolution. Nice stove. For $300 i couldnt let it slide by. I got all venting and a loveless ash vac included. Sometimes even i get lucky. But i am not getting rid of the englander. Its a tank.
Your loud noise you talk about could very well and most likely be the combustion blower. If you search around and shop you can get a new one fairly cheap. Even if its not "englander" specific just make sure the dimensions and rotation are the same. Most stoves use pretty much the same.
Stay warm but stay safe
Excellent, makes sense on the lfa for larger burn pots and I agree this baby is a tank thanks for this info I already looked into and found cheaper brand new combustion blower that will work with my unit. Purchased! Hope it helps the noise if mot I got a new combustion blower for very cheap. Thanks again. This baby is running great again.
