I have to replace my porch stairs. ( stringer and all) I bought premade stringers from lowes, but what is acceptable to for the risers and treads? The risers measure 6 5/8 " and the treads are 10"..( which will decrease after I put the risers on)
You might have to check with your local building inspector.
The standard for stairs is a min rise of 7" & a max run of 11"
See: http://www.ez-stairs.com/stair_calculator/
Daksy is right on this. If you are putting toe-kicks on each riser starting at the bottom, the distance does not decrease if using toe-kicks on each step. The treads usually overhang the toe-kicks a little to give you the proper tread depth. Sometimes if you can salvage the existing stringers, you can trace the rise and run on to the new piece of lumber.
http://www.blocklayer.com/stairs/stairseng.aspx
Enter the floor to sidewalk height where it says total rise. Fool with different combination of rise and run, but start with 10" run to see what the rise calculates.
7.5 rise 10 run
use 11 tread to have over hang
all riser must be within 1/8 inch per code
layout and cut carefully
rise can not exceed 7 5/8 or be less than 7
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
