Hello,
I recently purchased a house with a Efel Arden harmony woodstove. Date on the back says 1/90. The stove is connected to an outside chimney and is located on a first floor living room. The problem I am having is that I cannot get a hot fire running with just the baffles open full, it only smolders. But if I open the small door below the stove which is used to access the ash pan I get a great big fire, I think too big. Since it works well when it gets enough oxygen, and seems to be drafting great I assume the chimney is not the problem. I have read on the site some talk about having a negitive pressure situation in the house or it being too "tight", but that would suprise me since our house has some drafty doors and there is no other equipment competing for oxygen besides an oil furnace all the way at the other side of the house in the basement...
It seems to me that the fire is too starved with just the baffles but may be too hot with the ash pan door open...so i cant regulate in between. any idea on potential cause or correction? Also, what should the stove temp be when running, so i can make sure that im not getting to hot with the ash door open..
I have also read about OAK sytems (drawing air from outside) can these be installed on all stoves?..
Thanks in advance for any help, im loving my woodstove but would like to correct this problem ( without drilling holes in my stove!).
Kind
Kind
