Hi all. I've been burning at night for about 2 weeks or a bit longer here in East TN. I've installed a Magnaflex Insulflex 6" liner in my old masonary chimney this past August which seems to do really well with good draft.
I have a year old Quadrafire Yosemite which is a great little stove for my small 900 square ft. house. I know it's the shoulder season and it's easy to cook yourself out but seems like my stove wants to burn a little to fierce for my taste. I do have dryer wood this year per this forum. I've been burning a mix of willow, maple and oak.
What I usually do is build a small fire of an evening and burn with the screen on and the door swung open so I don't get so hot. When I remove the screen, load the stove for the night and shut both air controls all the way down. The stove top temp gets up to about 625F* and holds there with secondary burn coming on and staying on for a long time. I guess I'm just use to my old Fisher which I probably turned down to low but this seems a bit more fierce of a burn then I'd expect with the air shut all the way down. I do have enough coals after 7 hours or so to get going again but just seems a bit more free burning then I'd like. I have to open a few windows in the living room and shut the bedroom door when going to bed to be able to take it. Only had a few nights down the high 30's so far.
I have did the dollar bill test all around the doors and it seems pretty tight. I even swaped the washers around on the handles to tighten it up some more. The ash pan door is good and tightly shut. I adjusted the catch even tighter. I don't plan to use it anyway.
What do ya think? Could I block some of the air control off with a magnet? Do I need to do a smoke test or is this just pretty much normal? Like I say, I've been use to a Fisher for years which I could choke nearly off when I wanted too. By the way. Great forum. I don't post much but do a good bit of reading. Thanks A Bunch!!
