Question on flue size/draft issues with new woodstove install
NH_Wood
2,602
southern NH
Hello wood burners - have learned a lot from reading the posts on this site. First post for me - thanks in advance for your advice.
I am switching from a pellet stove to wood burning stove for next burn season (winter 2010/2011). Home is ~ 3000 sqft. Open concept 2000 sqft lower level and the rest of space upstairs (3 rooms). Large central chimney containing two flues - one for oil and one for fire place. Pellet stove is tapped into fireplace chimney flue on opposite side of fireplace. The tap occurs at the smoke shelf of the chimney, approximately 12-18" below the first tile. Fireplace flue is lined with 12" square tiles. My plan is to install a Hearthstone Mansfield woodstove, using the existing tap of the pellet stove. I have a few concern since the 12" flue tiles are larger than the 'guideline' of 3X the cross-section area of the 6" stove pipe. First - do you think I will have adequate draft? Again, I have about 20' of interior chimney, ~ 8' in the attic, and ~ 4' exiting the roof near the peak. So, I assumed that I would have good draft, even with large tiles, since the temperature difference between chimney air and outside air is likley quite high. Second - since the flue gases will cool within the larger flue space at a greater rate than within a 6 or 8" flue, should I expect high amounts of creosote near the top of the chimney? I am two years ahead on wood now, and will stay 2 years ahead, so I'll be burning very well seasoned wood. Lastly - is there a problem having a woodstove tapped into the chimney below the first tile? Thanks again for your help and have a very Merry Christmas!
Cheers
I say give it a shot.
If you can get it to draft initially, then just keep an eye on it.
Worst that can happen is that you'll hafta get back up there
drop a 6" SS liner/tee kit down.
Thanks Daksy - I'm hoping to avoid the liner, as I would like to keep the fireplace viable. I know that it is a no-no to start a fire in the fireplace with the stove running, but I'd like the option to use the fireplace when the stove is down. Thanks again.
Just hoping some additional folks might weigh in with their thoughts......thanks!
NH,
When I replaced my old stove three seasons ago, I vented the new stove into my 8" x 12", 25' clay lined chimney. I ran it that way for about two weeks with a sliggish draft. I then installed a 6" ss rigid liner and the stove really came alive. I clean the liner once a year with very little creosote.
Jim
Jim,
Thanks for your info - I'm assuming I may need to do the same, but will have to run a line through the ceiling and roof in order to keep fireplace alive - hoping to avoid, but perhaps I'll do as you did - give it a shot and then be prepared to run the liner if necessary. Thanks again! Cheers.
I say go ahead and do it right and reline, you won't want to burn the fireplace after you install the stove anyways. That 12x12 chimney is way too large and you will be disappointed in the stoves performance. You will have poor draft, coaling problems, and have to constantly fiddle with the air controls.
I agree, you will have draft problems with a flue that large. Spend the extra $$ for a good SS liner kit and avoid the hassle of experiencing problems that will lead you to needing to do it anyway after the fact.
Thanks Todd and MrFixIt - I have been trying to convince myself that the large flue would be okay, but I think you are both correct. Stove is expensive and wood is a lot of work (though I like it!) - so why end up with a poor burn season after doing all of the initial work and expense. Sounds like a liner is the way to go. Thanks for your responses! Cheers.
The liner is worth every penny and every minute of your time to install. I cannot emphasize this enough. Just read through some of the post titles and see how many people have stove performance issues where the root cause is the incorrect chimney size and poor draft.
I aso 2nd that once you get your stove fired up you will never use your fireplace again.
Well - I guess I'm sold on the liner - checking prices now. Another quick question. Is there a specific liner system for a liner going straight up through a lower level ceiling, second floor ceiling, attic, and roof? I assume I'll be using stove pipe to the first ceiling, then the liner for the rest (boxed in on the second floor). I guess I'm wondering about heat issues with the pipe as it exits the first ceiling, etc. Are they insulated in such a way as to avoid possible combustion? Also, the above roof portion of the new metal chimney will be within ~ 1 foot of the existing masonry chimney. Do I need to extend this portion above the masonry chimney, or can it be level with the masonry chimney? Thanks! Cheers.
P.S. Only want the the fireplace for aesthetic reasons - it is in the livingroom and we love the fire at night (plus, it seems to make the wife a tad more frisky...... ;-) ). The heating aspect is obviously minor, although it does make the room cozy.
