Rebuiding a 3CB
rwachtell
4
I am rebuilding a 3CB from parts and have a couple of questions.
1) After I scrape all old cement out of grooves is there a solvent I can use to clean things up and remove dust and ash residue from the surface so that the cement bonds more directly with the cast iron?
2) Should I use adhesive on all gaskets including the ones in the doors ( ash door and front door )?
3) Is there a way to tell if the baffle plate needs to be replaced?
Any suggestions on rebuilding this stove are appreciated.
Thanks Rob
You can use denatured alcohol for clean up. As far as the gasket you should use adhesive to place all of it. Is the baffle plate warped in any way? If not it is more then its fine. I have done a few of these in my day and i have a wire wheel that attaches to my cordless drill. It works great for getting it down to almost bare cast.
+1 on what Jotulguy sad. I just rebuilt my VC Resolute Acclaim. It burns better that new. Wire wheel was quick and easy. I don't recall the 3CB's interior. I did find that lilting the stove slightly with blocks under the front legs helped me get at some of the interior better.
ATB,
Mike
