Looking to install a fireplace insert + SS flue liner and live in Boston area. Does anyone have recommendations of reputable companies to work with?
Thanks for advice. The quote I referenced in my other post ($8,000 for installation of SS liner including 1/2" foil faced insulation blanket + stainless armor mesh + an additional $1,600 for removal + disposal of clay flue tiles for 30' of chimney ) is actually from Sweepnman (they cleaned my flues right after I bought house) and I'm looking for other quotes. I think a lot of the places that sell wood burning inserts around here outsource installation to chimney sweep companies.I’d recommend using a certified sweep to install instead of using whatever store you buy from.
I use SweepNMan every couple of years for a cleaning and once over look. They are probably a little more expensive for some things but everyone I’ve dealt with has always been good and honest.
https://sweepnman.com/chimney-fireplace-services/
Although that quote was pretty high, it is good that the company was talking about insulating the liners and what not. Keep in mind that’s basically the standard way of installing properly. If you hear from other companies that insulation is not needed, they Would be incorrect.Thanks for advice. The quote I referenced in my other post ($8,000 for installation of SS liner including 1/2" foil faced insulation blanket + stainless armor mesh + an additional $1,600 for removal + disposal of clay flue tiles for 30' of chimney ) is actually from Sweepnman (they cleaned my flues right after I bought house) and I'm looking for other quotes. I think a lot of the places that sell wood burning inserts around here outsource installation to chimney sweep companies.
Well no, many stove shops outsource to "installers" who do the absolute minimum they can get away with to keep price and time on the job to a minimum. Many of them will schedule 2 or 3 installs in a day.Thanks for advice. The quote I referenced in my other post ($8,000 for installation of SS liner including 1/2" foil faced insulation blanket + stainless armor mesh + an additional $1,600 for removal + disposal of clay flue tiles for 30' of chimney ) is actually from Sweepnman (they cleaned my flues right after I bought house) and I'm looking for other quotes. I think a lot of the places that sell wood burning inserts around here outsource installation to chimney sweep companies.
Good to know. I think it's a mixed bag around here. One stove shop I just called said they use Sweepnman (the sweep I got original quote from) for installs and the second one I called was more along the lines of what you were talking about - use "installers" that don't work for a specific company they're willing to reference by name, etc.Well no many stove shops outsource to "installers" who do the absolute minimum they can get away with to keep price and time on the job to a minimum. Many of them will schedule 2 or 3 installs in a day.
I know a former BI who worked there. I'll ask him.Melrose
is there not a difference depending on internal chimney vs external chimney? my understanding is insulated is need on external chimneys because of the exposure to cold.Although that quote was pretty high, it is good that the company was talking about insulating the liners and what not. Keep in mind that’s basically the standard way of installing properly. If you hear from other companies that insulation is not needed, they Would be incorrect.
It's more based on clearance requirements for the masonry chimney. 2" interior and 1" exterior. It's uncommon to see these honored, especially in older houses. An exterior chimney will definitely benefit more from an insulated liner. It helps keep the flue gases hotter which improves draft and can reduce creosote buildup.is there not a difference depending on internal chimney vs external chimney? my understanding is insulated is need on external chimneys because of the exposure to cold.
You can try www.csia.org to look for registered chimney sweeps in the area.
maybe pay by credit card for protection, or hold back 10% until satisfied.Just make sure to inspect the work. I had a CSIA certified sweep company do mine and it was subpar... Had to ask them to come back to fix the job. Still wasn't ideal but I'm satisfied enough.
