Removing plates from a older Mt Vernon Quadrafire.
Corrign
2
New England
I need access to the space behind the left hand side interior plate (wall?). I have taken out the top plate that covers the baffles, taken out the right hand plate (1 bolt),. I am stuck with the center back plate. I removed the two bolts holding it but it won't budge and I need to take it out in order to remove the left hand side plate. What am I missing? Any suggestions?
thanks!
Its been a while since I have seen an orig mv, thought had a couple of screws to remove and they come out. Have you tried rapping on it and maybe loosen it up from rust seize?? Kappel15 here on the forum will hopefully see this one, he is a Quad tech. I still like this stove though, it was a tremendous heater for its time.....
Hi Stovelark, yeah, I hit it with a hammer a few times and it's still locked up solid! You must have had much better luck than I've had, it;s been one problem after another for me....
