Room temp vs constant burn
Needhelpnow
4
Nh
just started my p43and room temp wasn't heating the house so I went to constant burn and couldn't control the temp. It was too hot so had to shut it dow. Have a ranch home 1200 sq ft. Well insulated. Would like a constant heat but not use a lot of pellets. Any suggestions? Should I turn it down when not around or just set it and forget it? Help
Try room temp auto with a feed rate at 4 and set to your desired temp. You should be able to control the temp with constant burn also. Might turn it down some if it's too hot.
