    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. HDRock Minister of Fire
    Grand Blanc, Mi
    I never actually burned during the Shoulder season before, so last week,when I started, I was cooking my butt.
    I'm getting a little better now, with smaller fires,but I need info on how to keep a hot fire and flue temp without ! over heating the house .
    Fire box is about 6 cub ft, EDIT: (9.5 cb ft) if it matters.
    Stove is a smoke dragon, so I'm not sure if this is the right place on the forum for this.
    #1
    Helpful Sponsor Ads!
  2. BrotherBart He Who Moderates
    Northern Virginia
    Ya wait till the house is getting a little below where you want the temp to be then let it burn down. Restarts in shoulder seasons are a regular routine here. Heat the joint up in the morning and let it go out. Live off of the residual heat and then restart at sundown.
    Try to keep smoldering small fires going and you just crap up the chimney and waste wood.
    HDRock likes this.
  3. HotCoals Minister of Fire
    Rochester,Ny.
    Your stove is meant to be a hot heater when it's cold out.
    A small fire is pretty much your only solution.
    Cold weather is a coming! lol
  4. clemsonfor Minister of Fire
    Greenwood county, SC
    Get a CAT stove. YOu can throttle that baby back to nothing and turn the blower way down. I am pretty much running 12 hours on a half a load of pine.
  5. BrowningBAR Minister of Fire
    Doylestown, PA
    Wow. So, how big is that house? Is it drafty? That's a big box.
  6. HDRock Minister of Fire
    Grand Blanc, Mi
    Yeah, the stove is big, was here when I bought the house, It's round, 36'' long, 24'' front to back, and then a blower on the back.
    House is1300 sq ft., it is not a tight house.
    Been looking at new and used stoves, not really in the budget,maybe next year.
    Don't think I have enough knowledge, just yet to pick a used one off CL
  7. BrowningBAR Minister of Fire
    Doylestown, PA
    I can relate on many levels.
    When the temps do get very cold does it still overheat the house?
  8. HDRock Minister of Fire
    Grand Blanc, Mi
    Well ! it will if I let it, but it's not so much overheating the rest of house, as it is the living room,(stove room) the rest of the house is not open, it is very cut up, if you know what I mean.
    I have been experimenting, with some ideas I learned on here, blowing cold air out of other end of house
  9. BrotherBart He Who Moderates
    Northern Virginia
    Oh well heck. That is just known at heating with wood.
  10. BrowningBAR Minister of Fire
    Doylestown, PA
    Again, I can relate as you can see from my signature.
    When you upgrade, unless you do a lot of insulating, you will have to over-size your next stove to provide adequate heating for your house. What size pipe does that stove use?
  11. HDRock Minister of Fire
    Grand Blanc, Mi
    I will try this:Live off of the residual heat and then restart.
    Good info, Restarts in shoulder seasons are a regular routine here
    Trying to keep smoldering small fires going and you just crap up the chimney and waste wood, is exactly what I want to avoid
    Yeah I know, but It's worse this time of year
  12. HDRock Minister of Fire
    Grand Blanc, Mi
    My pipe/chimney is 8'' straight up about 15ft from top of stove, to top of chimney, low pitch roof,and the hearth is built,1 ft off the floor, I get a good draft
  13. BrotherBart He Who Moderates
    Northern Virginia
    What stove do ya have?
  14. HDRock Minister of Fire
    Grand Blanc, Mi
  15. Backwoods Savage Minister of Fire
    Michigan
    That statement above is not necessarily true at all! If you have good fuel, you can do it and get away with it but you need good dry wood. The wood we burn is usually at least 3 years in the stack after it has been split. We have no problems with crapping up the chimney nor do we waste wood.
    rkshed likes this.
  16. BrowningBAR Minister of Fire
    Doylestown, PA
    Yeah, but he is using an old Non-EPA smoke dragon stove. If you try to have a low temp fire in a Non-EPA, your chimney is gonna have a bad time. Small and hot is his best solution with the old stove that he has, unless I'm missing something.
  17. Backwoods Savage Minister of Fire
    Michigan
    Not true in a non-epa. We burned all non-epa stoves before the Fireview. Only had creosote problems with one stove. All others did very nicely.
    nate379 likes this.
  18. HDRock Minister of Fire
    Grand Blanc, Mi
    I'm not quite sure what you are trying so say.
    I don't have creosote problems cuz I burn a good hot fire, cleaned the chimney a couple of week ago, and there wasn't' much to clean.
    Like I said I never burned in the shoulder season before and it is quite different.
    On top of that I rarely have the best wood, most of which I buy.
    I'm kind of a part time burner,and I thought I knew what I was doing, Ah ! Well I kinda do but, I have more to learn, and more planing ahead would probably help cuz, I have used good dry wood, not so dry and wood that was foaming as it burned
  19. BrowningBAR Minister of Fire
    Doylestown, PA
    I'm interested in hearing how you burn at low temps in a Non-EPA stove without smoke, as well.
    pen likes this.
  20. HDRock Minister of Fire
    Grand Blanc, Mi
    I just wanted to clarify, I did the math wrong, my stove is 9.5 cubic ft
    FrankMA likes this.
  21. nate379 Minister of Fire
    Palmer, Alaska
    I'll be happy to send you some cold temps. 5* tonight, wouldn't be surprised to see negative temps in the next week or two.
  22. HDRock Minister of Fire
    Grand Blanc, Mi
    ;lol Thanks for the offer, even though it would be easier to run the stove, I will pass.
    Still have work to do outside, once it gets down to 20 above, I don’t like to go outside;lol
  23. hilbiliarkiboi Member
    HotSprings NatlPark
    Gunna have to get a smaller stove. For now, do what you've been doing- just burn the condensate out by getting the temp up before shutdown.
  24. rkshed Member
    Bedford NH
    I agree.
    Our stove idles all day this time of year and I have no issues with a gunked up chimney, etc.
    I did accidentally get the house to 76 last night though which is way too hot.
  25. HDRock Minister of Fire
    Grand Blanc, Mi
    Way to hot ! That depends, on how a person likes it.
    One thing I have done , I stopped turning on the blower so it keeps the stove hotter with a small fire.
