Splitting Block Heigth?
Ralphie Boy
1,165
Rabbit Hash, Kentucky
I've never used one cause I've always split with a sledge and wedges. I just got an X27 so a block is in order. What should the height of the block be for a guy 5'11"
Try 16" and see if you like it. If not, try something else.
Take the fattest round and make that you block.
I always use a block whether I am using a maul or an axe.
Altho, I rarely use my axe because it seems everything I bring home requires a maul or sledge/wedge.
I like the handle of my X27straight out or parallel with the ground when it hits the wood. For me that is two pallets and my wood is 18". I am 5'11"
All the dimensions are the same, I think I'll try that. How long do your pallets last under all the pounding?
I would think pallets under a round would absorb a lot of energy plus have metal in them.
Reactions: Jon1270
To OP, just try it on the ground. No reason to pick something up you don't have to.
I use hard wood pallets screwed together then a piece of 1/2 inch of plywood screwed to the pallets and a tire screwed to that.
It works good for me. With the tire the blade never hits the pallet, the handle hits the tire first.
Splitting on the ground dulls the blade, in the tire the wood all stays together.
I stand corrected. I had no idea you were dealing with wood that small. In your situation that would work well.:)
I deal with a lot larger wood than that.
I like the tire idea. That is my next project. Bending over and sitting up again is most of the work.
How do you keep from breaking handle with pieces in middle?
It's the height that works best for YOU. I am 6'2 splitting 20 inch splits. So 18 works for me, of course in the tire. Large rds bigger than 20 dia get 1/4 on the ground then in the tire.
I whack the outside rounds first, the I aim for the ones on the inside. The handle usually finds the gaps.
I do this as well, I 1/4 the round to get it to fit in the 20" tire.
