stihl 290
Freeheat
[del][/del]Found a project on craigslist for a 290 farmboss with bad piston and cylinder for 40.00 Is it worth fixing , I want a winter project. or should I keep my money?
If you want to later resell..... make sure it is in good cosmetic condition, that will be the key when later selling. Be sure to include the word Farm Boss in any ad. You will have to use an aftermarket p/c in the rebuild to be able to make any money on the resale. Then you'll have to decide whether to disclose that to a potential buyer.
If you want to keep it for yourself, I'd pass. There are much better project saws out there.
Offer 20.00 not a penny more. Not many will take on a 290 you can quickly get in over your head in money. Unless you have a couple setting around already.
Yep!
I'd buy it cheap and find another with a good cylinder. Then you have a parts saw.
Thanks guys this saw is already in pieces so I would hope all the parts are there. I will offer 20 and see what happens
I charge 40.00 an hour on touched. 100.00 an hour if you touch it...lol Keep that in mind! ;-)
Offer 20, but I'd pay up to 40 and then drop a 390 piston and cylinder in there.
Yeah, don't waste your time re-jugging it with a 290/029. Look for a piston/jug from a 039/MS390 instead. Direct swap onto the 290 and a hell of a power boost. Takes it to 65cc.
jay ..i got a pretty nice running ms290...how much for u to beef it up into a 390?....and u get to keep the 290 stuff u pull off of it
looks to have too many parts missing but the other saw he is selling might be a good buy for someone here
(broken link removed to http://cleveland.craigslist.org/grd/2783855619.html)
That isn't worth 40. BTDT
Really? You wouldn't give $40 for OEM P&C, Crank assy, and a rewind starter? He'll get it.
Sure, if I had a saw that needed ALL of those parts. BTW, you can have good compression on a saw that has a nearly destroyed lower end. I'm wondering why this particular saw was condemned to parts status. Someone should ask the seller that question, because when I see a saw that has parts missing I assume they were used to put on a good saw. For example, if I have a saw with a bad coil and carb, they would go with the parts saw, why do I need them. What happened to the bad parts? I must not be trusting, I've just seen to many saws sold without significant, but small pieces so that you can't test the saw. It's like the infamous really clean looking saw with a broken starter cord. "works great, but you can't start it, trust me!"
Many 170's/017's were condemned to the parts heap for carb work or a bad coil.
Most customers flinched once the estimate got over the $70 mark and decided they really needed a 250 or 290 instead. Happens all the time.
Bought a (broken link removed to http://www.ebay.com/itm/320805966882?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649). It's a chinese part but aren't they all these days? Came to $65 shipped, with exchange.
Not all.
Meteor = Italy
NWP = Taiwan
TreePointer said:
Not all.
Meteor = Italy
NWP = Taiwan
Plus Mahle from Germany is OEM installed on Dolmar/Makita saws.Havent seen any of them sold separately though.
I forgot about Mahle. This past summer, I installed 79cc Mahle P&C kit from Bailey's onto a Makita 6401.
