The stove I have has a 8 " flue hole so I used 8 " I followed the 10,2 3 rule but I still get a back draft when I open both doors. I know 6" will create more draw . can I add a 6" section in the middle somewhere to get better draw
No, you will not get more draw with a 6" than with an 8".
Not sure what you mean about opening both doors. Perhaps a double door on the front?
Best thing you can do is to open the draft fully and wait about a minute before then opening the firebox door and open it slowly. Also, quite naturally, the chimney should be checked to see if it might be partially blocked. Good luck.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
