Stove pipe support bracket
Don Bedrick Posted By Don Bedrick, Jul 14, 2013 at 10:20 AM
Thread Status:
  1. Don Bedrick
    Don Bedrick
    New Member 2.
    NULL
    Jul 14, 2013
    8
    0
    Loc:
    Alaska
    Hi, I'm new to the forum.
    I have 15 feet of Simpson Dura Vent un insulated double wall sitting on top of two Simpson Dura Vent 45s. Long story why it has to be done this way. Any way, I think it's a lot of stress on those 45s and am looking for a decorative bracket that would bolt to the masonry behind the pipe and clamp/screw to the outer wall of the pipe above the 45s to take some of the load. I saw a wrought iron one years ago but can't find one now. Any one know where I can get one or have other suggestions? Thanks in advance.
  2. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,902
    8,631
    Loc:
    South Puget Sound, WA
    You could have a sheet metal shop make one up for you and paint it with BBQ black paint. Or would it be possible to put the offset at the top of the pipe instead of at the bottom?
  3. webby3650
    webby3650
    Master of Fire 2.
    NULL
    Sep 2, 2008
    7,180
    1,728
    Loc:
    Indiana
    Typically the 45's are at the top. The 45 get's screwed to the chimney adapter, the vertical pipe is screwed to the stovetop adapter. Then the slip section is expanded, and then screwed together, the slip really wedges everything together. If it's done like this, there should be plenty of stability.
  4. jeff_t
    jeff_t
    Minister of Fire 2.
    NULL
    Sep 14, 2008
    4,163
    1,114
    Loc:
    SE MI
    Picture would probably help to visualize.
  5. rideau
    rideau
    Minister of Fire 2.
    NULL
    Jan 12, 2012
    2,169
    817
    Loc:
    southern ontario
    If you need a strap, any blacksmiths near you? A good one could easily make whatever you want.
Thread Status:
