sweeping without dismantling pipe?
Nutmeg Warrior Posted By Nutmeg Warrior, Jan 11, 2013 at 11:27 AM
  1. Nutmeg Warrior
    Nutmeg Warrior
    New Member 2.
    NULL
    Dec 14, 2012
    63
    11
    Loc:
    CT
    This is my first season burning. I want to know if it's possible to sweep without taking everything apart, Can I just run a brush from the top of the liner or through the damper in the stove? Stove is a cat stove with rear exit flue. A few feet of horizontal stove pipe connects to a 25' liner.
  2. FyreBug
    FyreBug
    Minister of Fire 2.
    NULL
    Oct 6, 2010
    775
    146
    Loc:
    Kitchener, Ontario
    You may want to consider a telescopic straight section. They are available in single and double wall. Just disconnect the black pipe from the stove, slide up the telescopic part. Attach a plastic bag at the bottom and you're good to go. Sweep away and the stuff will fall in the bag.
  3. Monosperma
    Monosperma
    Member 2.
    NULL
    Jun 4, 2011
    109
    20
    Loc:
    Colorado/NewMexico
    I'm no expert, but the more you take a construct of thin pipe apart and put it together and take it a part and put it together, the more stress and metal fatigue at crucial points such as screw holes, and the more chance for failure. (Maybe you have full scaffolding and a team of workers to do it so there is no stress or metal fatigue, but I do not.) If you can clean the pipe well enough without disassembly, that's the way I'd go.
  4. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,930
    8,637
    Loc:
    South Puget Sound, WA
    If there's a tee connecting the horiz. stub to the liner, then yes. Pull off the cleanout cap, put a bag on the end and sweep.
  5. Nutmeg Warrior
    Nutmeg Warrior
    New Member 2.
    NULL
    Dec 14, 2012
    63
    11
    Loc:
    CT
    Thanks for the suggestion, FyreBug. I wasn't aware that such a product existed.
