mark123
That last picture is the cold air intake pipe, if you are refering to the previous picture, it does like like it in the picture but it is at least 3' from that wall.
Mark, would like to see pics of the oil plug you came up with. So far the AHS plug is serving it's purpose for me but it's not exactly a tight fit. I had to defeat the fan when burning oil...draft was way too high...did you have to do this too? I also rarely burn oil but when I do I have to watch on the initial burn as the flu temps get really high...a consequence to no fan running???
ac, not exactly picturing your Roxul/cap idea...pics??
I haven't hooked my oil up yet. The burner is attached, just not the lines. Should I be cleaning it out regularly? I think we may go away next year during the winter and I will need the oil by then. Should that lower hole be blocked?
I don't think I got an oil plug. No smoke coming from mine. Gonna have to get a good cleaning done then. Thx
That's the ticket. I have the auto version.Do you have auto or manual oil backup?
No plugs are supplied with auto as it could be very dangerous.
ac
ac
Yep, we almost experienced this first hand. I was out of town and the Mrs didn't want to hassle with wood so asked me on the phone can she burn oil to which I replied yes a long as you pull the plug. Well, she pulled large one and fired the boiler for a few minutes when she realized something was wrong. Thankfully she killed the power and called me right away! Got some smoke back up but that was a welcome outcome to what possibly could have happened!
yep!
I was having problems with the fan extinguishing the oil flame but a friend of mine who works on burners adjusted the air inlet on the burner and now it works fine, I don't know too much about oil burners but there is a little flap in there that can be adjusted, it is closed when the burner is off and then it opens so much when it is firing, you can limit how far it opens.
Lucky me, I randomly chose the Reillo over the Aero and Beckett when they offered me the 3 choices.
Actually I'm neutral on that subject but that reminds me of a thought I had since the topic of Wood Guns has arisen even though I have not been invited to participate in the conversation.LOL
I'm glad you shared. I'm sure one of the WG-haters will add this to the list of things wrong with the WG.
What would be nice is if one of you guys had the cojones to insert a secondary combustion air tube through that plug and through the access door with some sort of air adjusting mechanism. I only became familiar with the need for secondary combustion since junking my Wood Gun and had recently thought if the injection of secondary air would achieve a more complete combustion and get rid of that sulfur smelling exhaust that's common with the Wood Gun. I still think it is the odor of unburned wood gas.
