avc8130
With induced draft the air could come from the room. no other plumbing necessary.
EDIT: Oh I see. You don't want to drill a hole in your door
Correct, for 2 reasons.
1. If it doesn't work, I don't want a hole in the door since the door is complex made from steel and concrete of sorts.
2. How would I seal this hole up when there is no call for fire? Sticking with the intake would keep the air supply "off" when the damper closes. A separate hole in the door would not be closed when the damper closes.
ac
