this is a ? just out of curiosity,
If you have a chimney like duravent how many feet do you allow it to go above the roof into the outside air before you think about enclosing it to help draft?
i noticed some peoples chimneys on top their houses have a little box built around them that goes to about 2" from the cap even if its a thru the roof install..
last chimney i installed i left 5 feet sticking out above the roof and never seem to have a draft problem.
is it just for looks mostly to enclose it? when its a thru the roof install that is, i can see why it helps with a thru the wall one for sure tho.
