UGH -- Getting Smoked Out
Did you get a chance to check the cap? This is about the time of year when its cold that they get clogged.
Here is the pipe above the stove. About a cord burned i would say.
I am at a step back and meditate point. I thought I would be able to maintain this from inside the house. I have the tools. If, after a month, I need to go up on the roof and clean the cap that is not something I'm going to be able to maintain which does not bode well for project wood stove.
Someone today mentioned the method I was opening the stove...which was just to open it. And then it kinda clicked how quickly I can reverse the air flow in that system by sucking the air with the door opening...and not opening the air up all the way before I opened it. So maybe that's it...when the conditions are right I get the smoke...so I will try:
Opening the air up all the way an waiting a sec.
Opening the door a crack and waiting a sec.
Opening the door.
Sorry if I seem stupid....I am woodstove stupid!
I hope it's that simple, but don't forget the other suggestions if you do not believe the stove is operating to its potential
Opening the door.
I'd wait a minute or 2 ,this happened to me last year too .Same sort of conditions. The draft just stalled .Has not happened since "knock Wood" Also I don"t open Both doors till I know Its drafting
well....yes I would need to move the stove but then would no longer have a way to walk through...which I really like. A lot.
I will have to start looking into getting all new pipe ... that sounds like an expensive venture.
Move the walk through, then move the stove. You'll like the stove and the draft A lot and have a walk through to like too :cool:
I can't go on the roof....I haven't gotten that part opened up yet inside.
I check mine with binoculars from the ground, only go up if I have to. The ones with screens are the ones that tend to get build up, if you have one with a screen that gets build up just take the screen off or get another style cap that's not prone to build up.
If that is the build up at the bottom, the top is prolly caked. Best check your wood, or burn hotter.
Spray the chimney cap with a garden hose. It will clear it of soot build up and your draft will be fine. Same thing happened to me last night.
These are all good suggestions. I have the stove down right now and may not fire it up again this winter. I will buy another two cord of wood and stack it so I am ready when next year rolls around...and work on some things with the stove as well. Lots of decisions to be made still....I will keep learning. I still have a cord of wood so a couple more would be a good start for next year. I can't afford to buy all the wood I need for two years right now...and just burning the wet wood I have seems so counterproductive.
Reactions: pen
