    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. bobabuoy New Member
    IL
    I have a VC Encore 2n1 that I have had for a couple of years now. I have run it with the catalyst in place until recently, when I decided to try the non-cat mode. My question is why do I see more smoke coming out of the chimney when the bypass damper is closed than when the damper is open without the catalyst in place? What is the point of using the system in non cat mode with the damper closed if I get cleaner burning when the damper is opened?
    #1
    Helpful Sponsor Ads!
  2. defiant3 Feeling the Heat
    No. NH
    Indeed, what is the point of having a catalytic stove without a catalyst? Why not simply run an old Vigilant or something?
    I know how that may sound, but I am really not that snarky, I just have never fully understood the reasoning behind the 2 in 1. Have you had good results with yours? What do you like/dislike about it?
  3. bobabuoy New Member
    IL
    The only thing I can say I really like about the 2n1 aka "flexburn" is the look of the stove and the ashpan access area. I upgraded to the newer 2n1 a few years ago from a very old Vigilant, and have had draft issues and backpuffing ever since. My wife doesn't even feel comfortable using the stove when I am not present because it is so finicky.
    I have learned after a few years now of the tricks to working this stove, but it has always been used in catalytic mode. The recent switch to the non-cat is mainly because the catalyst is degrading, and I thought I'd give it a try in non-cat rather than spend the money to replace the cat.
    If I had to do it over again I would have purchased something else. The attention to detail on this expensive stove was not as good as it should have been.The gaskets on the glass windows were lose even when new, and the gasket to the damper and flue connector were out of place when new. The catalyst has not really been that rugged either - it lost shape early on and has now cracked in a few spots.
  4. defiant3 Feeling the Heat
    No. NH
    I'm still using my old Defiant because I can't afford a new one anyway, but the more I hear about the newer ones, the more I think poverty is a perverse blessing of sorts.
